need help asap! Knocking Noise
Old Jul 27, 2008 | 09:47 PM
1993_EG6's Avatar
Default need help asap! Knocking Noise
I got a 97 civic coupe
the car is a 5speed
my car is making some knocking sound. It starts while im driving it with my foot on the gas when I let off the gas the noise stops even with the gear on. I even feel the knocking on the gas petals.
First I was thinking about the clutch but then idk.
could it be anything else? axles,joints,???
If it helps by any chance I got a skunk2 camber and coilovers in the front with just new tires less than a week old. The noise started after getting those tires..
Old Jul 27, 2008 | 09:48 PM
OMGWTFBBQ!'s Avatar
Could be: bad axels, bad suspension ball joints, or the most likely, loose lug nuts. Check your lugs and see if that doesn't stop the sound.
Old Jul 27, 2008 | 10:07 PM
1993_EG6's Avatar
Checked the lugs but they are tight.
Old Jul 27, 2008 | 10:09 PM
OMGWTFBBQ!'s Avatar
Default Re: (1993_EG6)
Then jack your car up and shake the tire. It shouldn't have any play at all, if it does then you have bad balljoints. If it doesnt then inspect your CV joints for tears or leaking grease.
It also may be motor mounts, you should inspect all of them to be sure they're not causing it.
Old Jul 27, 2008 | 10:31 PM
1993_EG6's Avatar
I will sometime tomorrow. Thanks bro. I really dont know much this civic. I just traded my eg6 hatch for it.
Old Jul 28, 2008 | 01:47 AM
killektiv's Avatar
Im have the same issue right now. I believe that at least in my case its the axles. I found that one of them has been leaking grease for some time now and is about dry completely!
StockCivic07
Honda Civic (2006 - 2015)
Jun 29, 2018 05:50 PM
wafflecopter
Apr 3, 2015 11:53 PM
lalocivic
Dec 26, 2009 09:27 PM
scottblade
Feb 26, 2009 07:34 PM
Satoonxtreme
Mar 6, 2007 03:30 PM
