dyno problems, wont make anymore power on more boost?
Old Jul 27, 2008 | 08:45 PM
slotec's Avatar
Default dyno problems, wont make anymore power on more boost?
Went to the dyno the other day with my tuner to up the boost on my weekend/drag car. We were going to crank up the boost since I put in some 1000's and a boost controller. About an hour into the tuning session we got 360whp @14psi on a built b16, ITR cams, T70 turbo, Top Mount manifold, 4" downpipe straight to the ground. As we went to crank the boost up to 16-17psi and made 2 more pulls the numbers didnt change at all. We tried pulling timing on a pull then tried adding timing on another, but nothing changed. Me and my tuner were both stumped on why it decided to stop there when it had plenty more in it. I check and felt around on my couplers and on my manifold for any leaks but didnt see anything. Im still puzzled on what it could be.
This was also on a Dynojet that 98%+ used by mustangs and it didnt do a very good job picking up my rpm signal and I got no torque readings also was very hot out around 93-94 degrees
*UPDATE*
Pressure tested my charge piping at 30psi and I found a few small holes. Found 2 around the bov flange, another 2 right after the turbo on one of the charge pipe welds. Then I found the real problem 2 holes the size of headphone jacks that felt like I was blowing an airchuck into my hand. This explains why I would crank up the boost and no power was made because it was all leaking out before actually getting to the motor.
Modified by slotec at 9:28 PM 7/28/2008
Old Jul 27, 2008 | 08:55 PM
Humble Performance's Avatar
Default Re: dyno problems, wont make anymore power on more boost? (slotec)
Have you done a pressure test to see if there are any boost leaks anywhere ?
Just by the simple eye you are not going to see the leaks.
Old Jul 27, 2008 | 09:02 PM
Brent L's Avatar
dyno doesn't need tourque reading to tell you power
Check wategste diaphrams your source should be after cooler
what kind of cooler?? Check that exducer isnt melted any where
and all your vacuum lines are hooked up and correct
also what map sensor
Old Jul 27, 2008 | 09:09 PM
slotec's Avatar
Default Re: (Brent L)
Im going to try to pressure test it sometime this week. Both times Ive been to that dyno its had a hard time trying to get a good rpm signal. We didnt notice the problem with it not making anymore power until we hooked up the boost controller. The laptop read 17.8psi but my boost guage read about 18-19. All the vaccum lines were checked and hooked up correct. This is a GM 3 Bar map sensor tuning on Neptune RTP
Old Jul 27, 2008 | 09:20 PM
Default Re: (slotec)
Sounds like you have a leak a higher pressures , do a pressure test and I bet you will find your problem !
Old Jul 27, 2008 | 09:30 PM
slotec's Avatar
Default Re: (Humble Performance)
hoping its something simple causing this
Old Jul 27, 2008 | 09:46 PM
airwalk07143's Avatar
i experienced the same thing a month ago when i was on the dyno. It was a WARM day. and we werent making any power gains. We put a intake on the turbo to help it get cooler air and we instantly gained 90whp with no other changes. Sometimes the small things can rob you of power. What are you IAT's?
Old Jul 27, 2008 | 09:55 PM
slotec's Avatar
Default Re: (airwalk07143)
i dont remember what the IATs were but I do remember my tuner saying they were high and kept telling me to get a hondata IM gasket
Old Jul 28, 2008 | 12:25 AM
reaction360's Avatar
what kind of intercooler is it? is it a good core? or a heat soaking ebay one? I've seen this happend a couple times. also, how is your clutch holding up?
Old Jul 28, 2008 | 03:21 AM
nasteboyii's Avatar
clutch slipping?
Old Jul 28, 2008 | 04:11 AM
blackeg's Avatar
Default Re: dyno problems, wont make anymore power on more boost? (nasteboyii)
leaky blow off valve? is your dumptube dumping out near the intake?
Old Jul 28, 2008 | 04:26 AM
SPOOLINmatt's Avatar
Default Re: dyno problems, wont make anymore power on more boost? (blackeg)
the only T70 i know of is the eBay T70 that is actually a 52mm wheel.
Old Jul 28, 2008 | 05:27 AM
turbodano's Avatar
Default Re: dyno problems, wont make anymore power on more boost? (SPOOLINmatt)
I have had this happen when the clutch was slipping.
Old Jul 28, 2008 | 09:19 AM
slotec's Avatar
Default Re: dyno problems, wont make anymore power on more boost? (turbodano)
Its a 12x30x3 ebay intercooler and the downpipe comes off the turbo and straight to the ground as well as the dumptube. I just dont get how it could suck in the exhuast with the fans in front of the car on the dyno. Im going to try to make a pressure tester today and check for leaks on couplers and bov. The clutch is a 4 puck competition stage 5
Old Jul 28, 2008 | 09:46 AM
Drag_S14's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOOLINmatt &raquo;</TD></TR><TR><TD CLASS="quote">the only T70 i know of is the eBay T70 that is actually a 52mm wheel. </TD></TR></TABLE>
Old Jul 28, 2008 | 09:52 AM
Default Re: dyno problems, wont make anymore power on more boost? (Drag_S14)
That clutch should be able to hold that power no problem. unless its been used n abused and in need of replacement. I've seen other instances of where people made power to a point with there ebay intercoolers and could not go any further, then replaced the fmic with a garret core and immediately gained a huge amount of power.
Old Jul 28, 2008 | 09:57 AM
2fast4u831's Avatar
I'm really 2slow
Default Re: dyno problems, wont make anymore power on more boost? (reaction360)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reaction360 &raquo;</TD></TR><TR><TD CLASS="quote">That clutch should be able to hold that power no problem. unless its been used n abused and in need of replacement. I've seen other instances of where people made power to a point with there ebay intercoolers and could not go any further, then replaced the fmic with a garret core and immediately gained a huge amount of power.</TD></TR></TABLE> I remember someone gaining something like 80whp just on the cooler change.
Old Jul 28, 2008 | 09:58 AM
slotec's Avatar
Im thinking its the intercooler, but the turbo is actually a .70 compressor and a .82 exhuast side
Old Jul 28, 2008 | 05:28 PM
slotec's Avatar
*UPDATE*
Old Jul 28, 2008 | 06:02 PM
MrParks's Avatar
mf-10l my fav! good choice on the wheels!
Old Jul 28, 2008 | 08:38 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slotec &raquo;</TD></TR><TR><TD CLASS="quote">*UPDATE*
Pressure tested my charge piping at 30psi and I found a few small holes. Found 2 around the bov flange, another 2 right after the turbo on one of the charge pipe welds. Then I found the real problem 2 holes the size of headphone jacks that felt like I was blowing an airchuck into my hand. This explains why I would crank up the boost and no power was made because it was all leaking out before actually getting to the motor. </TD></TR></TABLE>
Get it fixed and go back to the dyno and crank that sucka up !
Old Jul 28, 2008 | 08:41 PM
Turbo-charged's Avatar
Default Re: dyno problems, wont make anymore power on more boost? (2fast4u831)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2fast4u831 &raquo;</TD></TR><TR><TD CLASS="quote"> I remember someone gaining something like 80whp just on the cooler change. </TD></TR></TABLE>
darrens car had similar gains and that was going from a PWR intercooler to a T1 intercooler....
Old Jul 29, 2008 | 05:47 PM
Silva Bullit DC4's Avatar
Default Re: dyno problems, wont make anymore power on more boost? (Humble Performance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Humble Performance &raquo;</TD></TR><TR><TD CLASS="quote">
Get it fixed and go back to the dyno and crank that sucka up !</TD></TR></TABLE>
X2, get it back on the rollers now that you got the piping problem fixed, Marcus. but I'd swap out the IC first. Try a TR10 from Treadstone. I switched from a 28x7x2.5 Ebay IC to a TR8 from them, and it worked wonders! The fin density was MUCH better than the Ebay unit. My IAT's were 132+ DEGREES with that Ebay cooler!
Here ya go: http://www.treadstoneperforman...olers
Old Jul 29, 2008 | 09:42 PM
slotec's Avatar
Default Re: dyno problems, wont make anymore power on more boost? (Silva Bullit DC4)
the intercooler is fine for now my buddy made 700whp in his supra with the same intercooler. Im saving for a T1 intercooler. Other than that Im getting a hondata IM gasket and putting the piping back on since I just got it fixed tonite. Now Im ready for 30psi
Old Jul 29, 2008 | 09:45 PM
Good luck man !
