ground wire?
Old Jul 27, 2008 | 07:45 PM
tyler100's Avatar
Default ground wire?
can anyone show me where all my ground wires go? and about my fuse problem the dash lights and ciggy lighter and cd player fuse is only getting power to one side?
Old Jul 27, 2008 | 10:15 PM
tyler100's Avatar
Default Re: ground wire? (tyler100)
Old Jul 28, 2008 | 06:01 AM
beige89civic's Avatar
* B A N N E D *
Have you checked all fuses? Even the ones under the hood?
Old Jul 28, 2008 | 08:49 AM
tyler100's Avatar
Default Re: ground wire? (beige89civic)
checked all of them . there all good,.
Old Jul 28, 2008 | 10:47 AM
tyler100's Avatar
anyone else? this is pissing me off bad.
Old Jul 28, 2008 | 12:18 PM
* B A N N E D *
Are you only getting power to that one fuse? Maybe your Ignition switch is bad. Need more information
Old Jul 28, 2008 | 02:43 PM
tyler100's Avatar
im getting power to my fuses but on the interior light fuse only one side of the fuse is getting power. i check it w. a test light and one side of the fuse spot is getting power through it.
Old Jul 28, 2008 | 06:12 PM
tyler100's Avatar
Old Jul 28, 2008 | 06:38 PM
BILLETGRIP's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tyler100 &raquo;</TD></TR><TR><TD CLASS="quote">im getting power to my fuses but on the interior light fuse only one side of the fuse is getting power. i check it w. a test light and one side of the fuse spot is getting power through it. </TD></TR></TABLE>
that means the fuse is blown
Old Jul 28, 2008 | 06:49 PM
tyler100's Avatar
Default Re: ground wire? (BILLETGRIP)
no when i took the fuse out it and tested each side with a test light only one side of the fuse block, "where you plug the fuse in " it only lights up on one side.
Old Jul 28, 2008 | 06:52 PM
BILLETGRIP's Avatar
yeah its supposed to do that when it doesnt have a fuse in it. put the fuse back in and then test each side of the fuse through the top of the fuse. or just try putting another fuse in it
Old Jul 28, 2008 | 07:56 PM
tyler100's Avatar
alright will do. thanks.
Old Jul 29, 2008 | 11:44 AM
Aristotle's Avatar
Ef's only have three grounds in the engine compartment. Engine to radiator support, chassis to transmission, and battery to chassis.
Old Jul 29, 2008 | 07:13 PM
tyler100's Avatar
Default Re: (Aristotle)
thanks man. think of why my interior lights aint working? its not my fuse.
boostedefhatch
Audio / Security / Video
Jul 10, 2009 12:15 PM
-Championship-
Nov 2, 2006 01:22 PM
9500redline
Oct 28, 2005 06:25 PM
_Cyclone_
Jul 17, 2005 08:06 AM
SLOAZZ95
Oct 6, 2003 09:32 PM
