Perplexed. Front knuckle removal. what went wrong?
Old Jul 27, 2008 | 04:17 PM
AlphaKennyWun's Avatar
Default Perplexed. Front knuckle removal. what went wrong?
I went through all the FAQs, search and google. Could not get the knuckle off so what went wrong?
Sequence of events:
removed tire and wheel
removed 32mm axle nut
removed entire brake assembly
removed lower ball joint circlip and nut
removed tie rod circlip and nut
removed upper knuckle wishbone nuts (ones under hood)
went as far as removing upper and lower shock mounts (was I supposed to?)
The last thing left were the lower ball joint and tie rod joints.
I used the ratchet method, hammer method, a jack to support the LBJ, jumped on the ratchet etc and finally I just gave up so I ask what went wrong?
Old Jul 27, 2008 | 05:01 PM
black0hatch's Avatar
Default Re: Perplexed. Front knuckle removal. what went wrong? (AlphaKennyWun)
it might have helped to keep the suspension on but its not totaly necesary. when you stick the rachet in there drop the jack fast if it doesnt pop then jump on the hub not the rachet. soak it with some pb.
Old Jul 27, 2008 | 05:20 PM
traxxasx's Avatar
http://youtube.com/watch?v=ISY8bGof3bQ
Old Jul 27, 2008 | 07:26 PM
Default Re: (traxxasx)
oh good lord. I was jumping on the ratchet. I had watched that video but a poor quality one. THAT shows it alot better. Thanks.
Also very important, does the tie rod (sort of above and behind) pop out simultaneously or can one lift it out?
One last thing, lol, for the axle thats in the knuckle, can I just slide the knuckle out by pulling it away from the axle or how else does it come out? Thanks.
Old Aug 9, 2008 | 04:17 AM
Default Re: (AlphaKennyWun)
What do i need to get the hub spline off the axle?
I read I need a big 2 or 3 jaw puller?
Modified by AlphaKennyWun at 8:26 AM 8/9/2008
Old Aug 9, 2008 | 09:20 AM
johnnyonth3spot's Avatar
Just tap it with a brass hammer or use the corner of a 3 pound hammer just dont hit anywhere near the threads, it doesnt ususally take much then pull knuckle out.
hot hatch man
Sep 26, 2015 11:13 AM
HONDRETTI
Dec 31, 2008 05:06 PM
vtechrex
Jan 31, 2006 09:06 PM
allmotorEG-SI
Apr 17, 2005 05:52 PM
2camsaam
21
Oct 1, 2003 07:32 PM
