how do i check fluid level for tranny.. b18b?
Old Jul 21, 2002 | 02:28 PM
Integra_Boi's Avatar
New User
Default how do i check fluid level for tranny.. b18b?
i dont see a dip stick or nething to check it...
Old Jul 21, 2002 | 02:51 PM
Regular Series's Avatar
Default Re: how do i check fluid level for tranny.. b18b? (Integra_Boi)
Do you have a manual tranny? If you do, you have to take out your tranny filler bolt to check the level. It's a 12 mm bolt sitting near the top of the tranny housing on the passenger side, near the engine. Pull the bolt, stick in your finger. If there's fluid at the bottom of the hole, you're OK. Otherwise, add fluid (a funnel and a length of rubber hose are indispensable for this job).
Also, I'd say blow $12 on a Haynes manual. They have pictures and slightly more detailed instructions.
Old Jul 21, 2002 | 03:30 PM
New User
Default Re: how do i check fluid level for tranny.. b18b? (risingson77)
oh yea i filled it before, just never really checked it..
Old Jul 21, 2002 | 03:32 PM
Mase's Avatar
yep the best way to check is to do what he said, if its not to the bottom of the filler, just add some slowly until it pours out...but make sure the car is level
Old Jul 21, 2002 | 03:33 PM
Well, then that's how you check it. With a manual tranny, you don't have to worry about the fluid level unless you have a leak. That's why there isn't an easier way to check it.
spikey0123
Nov 29, 2011 03:27 AM
Jimster480
33
Oct 5, 2009 05:21 AM
Redprelude98
Jan 2, 2009 03:26 PM
korndog
Jan 26, 2005 02:16 PM
01-1293
Jul 9, 2002 08:34 PM
