neeed help!!!
ok i really need help with my 94 honda accord ex manual. vtec. it is really jumpy when taking off and driving under 2k rpm. i think its the spark plug wires in wrong place any 1 got a (Good) diagram of where they go.also the idle is on the first line after starting it any info will help ty
Well--first off, if you did put the spark plugs in the wrong spots you're timing would be completly off, therfore causing your caure to miss-fire and not start completly. What i would suggest is checking the wires and makeing sure that they are in the vavles all the way. Sometimes if they are loosley hanging out it will cause they vehicle to run extremly rough and loose a lot of power.
Also, I wasn't aware that their was a difference on a manual and automatic head. I know that their is an obviuse differnece in Transmissions and ECU's, but not heads. To my knowladge i thought the only real differnce was the V-tec wiring. Make sure that your V-tec harness and everything else is all hooked up correctly.
Hope that helps, good luck!
trazzaqui915
Feb 24, 2010 10:02 AM
Ohbebe75
Sep 16, 2009 01:20 PM
RedGSR
Jun 24, 2004 09:17 PM
