how can i tell if my trans is a b16???
Old Jul 27, 2008 | 12:04 PM
little2fast4u's Avatar
Default how can i tell if my trans is a b16???
i bought this trans of a kid. he said it was a ys1 but not sure if it was lsd so i looked at it and it isnt lsd. i know the ys1 trans came in the ls integra the xsi integra with lsd and the usdm b17 gsr da integra. but how can i tell if it is a b16 or b17 trans and not the b18 ls trans??? the sticker number is "ys1 1009784" is there any way to look up the numbers and find out exactly what kind of car this trans come out of?
Old Jul 27, 2008 | 02:52 PM
hotrod99's Avatar
Default Re: how can i tell if my trans is a b16??? (little2fast4u)
i think the ys1 is actaully a usdm b18a LS transmission
Old Jul 27, 2008 | 05:56 PM
this is what i found when i googled ys1 specs but how can i confirm that it is indeed a b16 trans? would the honda dealer be able to tell?
http://www.clubintegra.com/boa...=6053
Old Jul 27, 2008 | 11:37 PM
vtecb18c's Avatar
Default Re: (little2fast4u)
ys1 and a1 trannys are usdm LS trannys...i believe only the jdm ys1 tranny was out of a b16
Old Jul 30, 2008 | 01:13 PM
is there any way to tell if it is jdm?
Old Aug 2, 2008 | 06:46 PM
bump
Old Aug 3, 2008 | 09:04 PM
Gearspeed-Performance's Avatar
There are a few methods of checking what model the transmission is by counting the rotations of the mainshaft and marking them...there is a thread on here somewhere.
The true way to know without a doubt is to open the transmission up and do a tooth count. That will be the 100% way.
The YS-1 is an identifier but, the numbers after mean nothing to us nor to a dealership....so they are of no use.
Either way...if the transmission is good internally..it is a good one to have. It is the only cable transmission that accepts parts from newer model hydraulic clutch actuated transmissions. So hang on to it! Interchangeability is a plus these days!
Old Aug 5, 2008 | 04:57 PM
Default Re: (Special Projects MS)
wow man thanks for the info on the tranny you seem like you really know your stuff. can i change over everything from a newer b16 hydro tranny into my ys1? and does the usdm b16 tranny come lsd?
Old Aug 5, 2008 | 09:56 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by little2fast4u &raquo;</TD></TR><TR><TD CLASS="quote">wow man thanks for the info on the tranny you seem like you really know your stuff. can i change over everything from a newer b16 hydro tranny into my ys1? and does the usdm b16 tranny come lsd?</TD></TR></TABLE>
Yes you can and No the USDM B16 Hydro trans did not come with LSD.
tfsmith8
Transmission & Drivetrain
12
May 27, 2013 06:06 AM
DA3
Jun 5, 2009 07:21 PM
allnaturalb16
Nov 4, 2006 06:16 PM
tial-eg
Jun 30, 2006 03:26 PM
shotty527
Sep 20, 2003 06:48 AM
