Rear clunking noise from rear passenger side tire
ok, I am just stumped at this point need a little help from ht. I did a rear disk swap maybe 4 months ago changed the trailing arm bushing as well with new oem ones. Every since then i have had a rear clunking noise only when i go over big bumps, I just cant stand it anymore, I have checking everything on that side and i am yet to look if any bolts are loose, which i will do when i get off work. I know it is not the shock because i switched my rear shocks which each other to see if the strut was blown and the same noise came, so i have eliminated the strut, I have eliminated the bushing only because they are new and i am only getting noise from the back left side. I have searched weird noises coming from rear and most people pin point it to the trailing arm bushing, but i dont think it is mine because they are straight from the factor so my idea's are done I just cant stand the noise anymore if anyone can help please let me know if not ill try and solve it on my own thanks h-t.
top plate bushing ....(sleeve)
sway bar may knock on the LCA
exhaut touch the sway bar
Torque everything, with a torque wrench as supposed..
its not the shock since i switched the shocks because the right makes no noise, so i swaped them and the noise still happens so it eliminated the shock or the bushings ne more suggestions i have the car on four jack stands right now since i am changing the pads, the oil and putting in hid fogs and all the bolts seems torqued i am going to go torque them down after dinner hopefully one is loose, but none seem lose
turbotime
May 6, 2007 03:21 PM
