FS: 00-01 *ITR Cams and Gears
Old Jul 27, 2008 | 10:59 AM
nate_2k5's Avatar
Default FS: 00-01 *ITR Cams and Gears
got a set of 00-01 ITR cams, same as CTR cams, looking for 280 shipped obo
Modified by nate_2k5 at 8:06 AM 7/30/2008
Old Jul 27, 2008 | 05:18 PM
nate_2k5's Avatar
Default Re: FS: 00-01 *ITR Cams and Gears (nate_2k5)
Old Jul 29, 2008 | 06:44 PM
nate_2k5's Avatar
Old Jul 29, 2008 | 06:59 PM
rickykline's Avatar
same as ctr? i thought they were different cams?
Old Jul 29, 2008 | 07:49 PM
842177's Avatar
pics?
Old Jul 30, 2008 | 05:05 AM
nate_2k5's Avatar
Default Re: FS: 00-01 *ITR Cams and Gears (rickykline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rickykline &raquo;</TD></TR><TR><TD CLASS="quote">same as ctr? i thought they were different cams?</TD></TR></TABLE>
not after 2000, they are the same.
Old Jul 30, 2008 | 05:07 AM
nate_2k5's Avatar
Default Re: FS: 00-01 *ITR Cams and Gears (842177)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 842177 &raquo;</TD></TR><TR><TD CLASS="quote">pics?</TD></TR></TABLE>
pics up
Old Jul 30, 2008 | 05:50 AM
tamadrumr88's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nate_2k5 &raquo;</TD></TR><TR><TD CLASS="quote">
not after 2000, they are the same.</TD></TR></TABLE>
ctr intake cam has 3* more duration.... will you part with just the intake cam? pm me
Old Jul 30, 2008 | 04:19 PM
nate_2k5's Avatar
Old Jul 31, 2008 | 02:02 PM
94VTEC2TONE's Avatar
willing to do any trades? and how many miles on the cams
Old Jul 31, 2008 | 04:48 PM
nate_2k5's Avatar
Default Re: (94VTEC2TONE)
what kinda trades, around 40k
Old Jul 31, 2008 | 04:50 PM
i got a gsr manifold, 650 cc injectors. something like taht do? pm me and well try to workout a deal
Old Aug 1, 2008 | 08:24 AM
mouab18c1's Avatar
these dont look like 00-01 itr cams...or is it just the crappy pic quality of the intake cam...00-01 itr cams have two lobes at the end....
Old Aug 1, 2008 | 01:26 PM
nate_2k5's Avatar
Default Re: (mouab18c1)
i think you may be right, after a little bit of research they may be 96-99 usdm itr cams. not a huge deal as the 3 degrees doesn't equate to any noticeable power gain
Old Aug 1, 2008 | 09:16 PM
mouab18c1's Avatar
Default Re: (nate_2k5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nate_2k5 &raquo;</TD></TR><TR><TD CLASS="quote">i think you may be right, after a little bit of research they may be 96-99 usdm itr cams. not a huge deal as the 3 degrees doesn't equate to any noticeable power gain</TD></TR></TABLE>
actually it makes a big difference....00-01 are way better then the 96-99 ones....and to me it looks like b16 cams...but hopefully you are right about them being 96-99 itrs.
Old Aug 1, 2008 | 11:25 PM
spoonhatchblack's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mouab18c1 &raquo;</TD></TR><TR><TD CLASS="quote">these dont look like 00-01 itr cams...or is it just the crappy pic quality of the intake cam...00-01 itr cams have two lobes at the end....</TD></TR></TABLE>
True That!
Those Cams are 100% Pre-98 ITR Cams
Old Aug 3, 2008 | 12:16 AM
nate_2k5's Avatar
actually it makes a big difference....00-01 are way better then the 96-99 ones....and to me it looks like b16 cams...but hopefully you are right about them being 96-99 itrs.</TD></TR></TABLE>
they are not WAY better, if they were explain why the power figures did not change between years...
Old Aug 3, 2008 | 08:03 AM
mouab18c1's Avatar
they are not WAY better, if they were explain why the power figures did not change between years...</TD></TR></TABLE>
actually they are because 00-01 itr cams are almost the same as Skunk2 S1 cams...if you were to dyno them you would see different and better results with the 00-01 cams.....and im wondering if you have ever had any expereince with the 00-01 ITR cams...if you havent you should try them...you'll notice the difference of VTEC
Old Aug 3, 2008 | 08:16 AM
oneiro's Avatar
wow, you must have really good eyes, if you can almost tell they're b16 cams, cause I couldn't really tell between GSR/B16/ITR cams, Unless I measured it.
Old Aug 3, 2008 | 08:26 AM
mouab18c1's Avatar
Default Re: (oneiro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oneiro &raquo;</TD></TR><TR><TD CLASS="quote">wow, you must have really good eyes, if you can almost tell they're b16 cams, cause I couldn't really tell between GSR/B16/ITR cams, Unless I measured it.</TD></TR></TABLE>
why would you measure it? they're are different patterns on all intake cams....and yea i have pretty good eyesight...ahahhaha..and actually it has one lobe on the intake cam...for what i see
Old Aug 3, 2008 | 08:37 AM
unified112's Avatar
http://www.superhonda .com/forum/f11/ctr-cams-19205/
Yes, the 00-01 USDM ITR cam is the EXACT same as the JDM ITR/CTR cam, '3 degrees of duration and all'. Obviously they're just different part numbers. And as stated in the link, '00 cams are good for maybe 5whp over '99 style cams.
Props to FF-Squad and SHO for the info.
Old Aug 3, 2008 | 01:49 PM
nate_2k5's Avatar
Default Re: (unified112)
anyways...i was sold these as 00 jdm itr cams, and according to that link i was correct. but they are not ctr cams i guess...
Old Aug 3, 2008 | 01:51 PM
nate_2k5's Avatar
you'll notice the difference of VTEC </TD></TR></TABLE>
i think i will feel the difference of VTEC a lot more when i got from itr cams to skunk2 pro 2's
Old Aug 3, 2008 | 02:01 PM
mouab18c1's Avatar
i think i will feel the difference of VTEC a lot more when i got from itr cams to skunk2 pro 2's </TD></TR></TABLE>
ahaha watever u can afford
Old Aug 5, 2008 | 06:54 AM
nate_2k5's Avatar
bumps
EF9status
Sep 7, 2008 06:15 PM
b18 hatch mike
Aug 23, 2007 03:29 PM
b18c-1
Jun 14, 2006 12:55 PM
Beezer
Dec 19, 2004 05:29 PM
MUGEN_B16CIVIC
12
Mar 27, 2004 07:49 AM
