crx b18b
i have a crx dx and im wanting to put in a b18b but i dono the deal about the obd0 and obd2 but how would i convert my crx to obd2/what is a crx obd0?? or is there a b18b with obd0 and what other things would i have to do to put a b18b in a crx
first you need to convert your dpfi engine harness to mpfi. then the easyest thing is to make the b18 obd0 because your crx is obd0. to do this you need obd0 integra dizzy, ecu, fuel injectors, and a single wire o2 all that off a b18a1. and your gona need the cable tranny off that same car and throttle cable and hoses. your also gona need mounts and linkage. just search its the easyest b swap imo.
yap just do what black0hatch say..... its very easy as long you have everthing. you dont need to convert it to obd2, i have 88 crx si with 98 Rs b18b1, i use the 94 valve cover, haha.just get a pr4 obd0 ecu.....
But right now, I'm running Lsv w/ p72 obd1 i make my own obd0 to obd1 harness and dizzy harness hahah,
Modified by jdong at 10:58 AM 7/27/2008
CRXRTYPE
Aug 5, 2004 01:02 PM
