wtb. d16z6
im looking for a complete longblock d16z6 within 100 miles of knoxville tn. if it dosent have the alt or somthing thats find but intake and tb and everything else needs to be present . it needs to be in good running condition with less then 190k on it
I have one with 0 miles on it fresh build. Arp rod bolts and head studs. Bored out .5mm with P29 pistons ~12-1 comp ratio. Head milled .25mm smoothed ports (not a P&P just improved) Y8 intake manifold B16 throttle body matched. I have not installed the cam yet as I was debating installing an aftermarket cam (stage 1). All new bearings, oil pump, water pump, gaskets, tensioner and more. I did not replace the valve springs as I was only building this for a "mild" street engine maintaining fuel economy and reliability.
I have a change in plans so I will move this on.
I have over $700 invested in parts and machine work alone. I will let it go for that much as well. I have the exhaust manifold, distributor and alternator as well. The wire harness is there too, but I can't remember if its intact or not. I know most of it was there, but haven't looked at it in a few months.
likuidphreon
Oct 23, 2013 11:01 AM
johng
Northwest (Sales)
Jun 20, 2005 01:14 PM
cotay (egb18c)
Aug 29, 2002 04:17 AM
