03 type s srs and abs light
Check ALLDATA...I believe there is a TSB on the SRS light coming on unwarranted. As far as the ABS light....I'm guessing bad sensor...and yes, if you take the bulb out...the ABS will still not work. You have to get it read and fixed or you will be minus anti-lock brakes sir.
