D15B2 w/P28 CEL?
Old Jul 26, 2008 | 05:02 PM
Kaeon's Avatar
Default D15B2 w/P28 CEL?
I have a D15B2 in my Del Sol, I just got my P28 Flashed with a base map for the D15B2 motor & installed my conversion harness. When I plugged it in, The car threw a CEL. I checked the light blinks, and it is (14) ICS Malfunction. My buddy tells me that a wire or two needs to be moved to a different pin in order to get the CEL off. The idle is going up to 1500 then dropping down right now. Does anyone know what needs to be done?
Old Jul 26, 2008 | 07:46 PM
Relic1's Avatar
CEL 14 = Air idle control valve.
more than likely the AICV is bad or wired incorrectly.
have him move the wires so it's right.
Old Jul 26, 2008 | 09:43 PM
vtecb18c's Avatar
Default Re: (Relic1)
x2^^ rpm fluctuation is usually caused by the IACv
Old Jul 27, 2008 | 04:23 AM
Kaeon's Avatar
Default Re: (vtecb18c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">CEL 14 = Air idle control valve.
have him move the wires so it's right.</TD></TR></TABLE>
I know it is wired incorrectly, I don't know were the wires need the be moved too. That's the info I was looking for.
Old Jul 27, 2008 | 07:45 AM
Relic1's Avatar
A9 for one side, ignition switched for the other.
Where they go from the ECU to the AICV is a good question, it all depends on how he ran the wires.
Aquafina
Jun 10, 2007 05:34 PM
tweekerz
Nov 27, 2006 03:22 AM
B00ST2nR
Apr 18, 2003 04:03 PM
