99 accord ex suddenly wont start
Old Jul 26, 2008 | 04:53 PM
dmfine71's Avatar
Default 99 accord ex suddenly wont start
Drove car (99 accord ex) this morning, started fine, then this afternoon won't start, doesn't turn over at all, battery seems fine
bad fuse, or bad starter?
if it's a bad fuse, which one? the manual doesn't tell you which fuse controls starting/ignition
Dave
Old Jul 26, 2008 | 04:56 PM
phootbag's Avatar
Default Re: 99 accord ex suddenly wont start (dmfine71)
Do you hear a loud 'click' that seems to come from under the hood? Do the indicator lights come on? Manual or automatic? What color pants was your garbage man wearing three weeks ago?
More information is better than less.
Old Jul 27, 2008 | 07:35 AM
dmfine71's Avatar
Default Re: 99 accord ex suddenly wont start (phootbag)
no loud click, it's as if turning the key to the III spot is no different than the II or I spot.
engine doesn't turn over at all
automatic transmission
started fine earlier yesterday
tried jumping the battery, did nothing, lights work fine
Old Jul 27, 2008 | 01:40 PM
phootbag's Avatar
Do you have an aftermarket security system installed?
Old Jul 27, 2008 | 03:09 PM
boostedh23's Avatar
possible starter issue or security system, if no security system >check first to see if the starter is getting voltage, is yes then swap it out
Old Jul 28, 2008 | 10:33 AM
EuroKing99's Avatar
Default Re: 99 accord ex suddenly wont start (boostedh23)
also, check the ignition switch since those years had a recall. if thats good, check the main relay. that fixed my problem.
Old Jul 28, 2008 | 11:08 AM
Cannon Man's Avatar
Ignition. Mine did that a few weeks ago when I went to start it in the morning and got nothing, I came home I turned it to the III pos. and after a sec the dash lights came on and it started right up. You should take it in for the recall if it hasnt been done already
Old Jul 28, 2008 | 12:29 PM
Heat's Avatar
First thing to do would be to call or stop by a dealer with your VIN, see if the ignition switch recall was done for your car. If not, do it, it's most likely the problem.
If that's not it, check your battery, make sure it's fully charged and take a little time to clean the terminals / terminal clamps with a battery terminal cleaner (they are a heavy duty brush made specifically for this job, costs $1 or $2 at your local hardware store).
If that's not it then there's a good chance that your starter is acting up, there are copper plates (solenoid contacts) that wear down over time. I've never removed my Accord's starter but when I removed my Camry's starter and took it to a shop, it cost $25 to have new solenoid contacts put on, the plunger reground, brushes looked at / cleaned, everything put back together and then the unit was tested.
Old Jul 28, 2008 | 07:00 PM
RyanJWoods's Avatar
If it occurs only when the weather is hot or the car is parked in the sun for a while, check you main relay it may need to be fixed or replaced. Heat and high internal cabin temps cause the main relay to get to hot and then it just won't work.
Old Jul 29, 2008 | 04:48 PM
phootbag's Avatar
Default Re: 99 accord ex suddenly wont start (RyanJWoods)
The main relay normally won't keep the car from cranking.
Old Jul 29, 2008 | 05:35 PM
02 accord's Avatar
Make sure that your shifter is either in P or N. A light on the cluster will confirm that.
pyrosee
Jan 27, 2015 06:44 AM
Richteje
Aug 4, 2014 08:02 PM
voodooutt
Feb 11, 2007 12:20 PM
Nata$
Oct 18, 2006 12:36 PM
