idle quesion with tps sensor
i was curious if there are no cel does that mean the tps sensor is still working?
what are the symptons with a bad tps sensor?
my idle is like a roller coaster. it goes up and down kinda like this integra in the youtube video.
http://youtube.com/watch?v=bH6...lated
i have an issue with idle and i was curious if this was the problem.
Modified by 949 at 11:44 AM 7/26/2008
If you have a 88-91 1.5 litre there's a ground wire TSB you could try. You replace the ground wire and ground it to the intake manifold. The TSB suggests a fault in the ground of the tps circuit causing an idle fluctuation. ALso, if your throttle cable is too tight the IAC motor has a difficult time maintaining idle.
No Problem! Here's the TSB (Here's the Part Number for the wire P/N 32105-PM5-315. It's like 6 bucks. very easy to do)
1989 Honda Civic Sedan L4-1493cc 1.5L SOHC (D15B2) TBI
Vehicle Level Technical Service Bulletins All Technical Service Bulletins Engine - Occasional Rough Idle
Notes
91honda04
Bulletin No.
91-031
Issue Date
NOV. 1, 1991
File Under
ENGINE
Model
'89-91
CIVIC
Applicable To
SEE VEHICLES
AFFECTED
SYMPTOM
1. The engine may occasionally idle roughly or erratically after coming to a stop with the throttle fully-closed.
2. On 1990-91 cars equipped with automatic transmission: Even though the proper procedure is followed, the shift interlock system may occasionally prevent the driver from shifting out of Park.
VEHICLES AFFECTED
All 1988-91 Civic models equipped with 1.5 liter engine and dual-point injection, thru VIN:
1HGED3...ML011574 (Sedan)
2HGED6...MH512869 (Hatchback)
JHMED3...MS031565 (Sedan)
JHMED8...MS012826 (CRX DX)
JHMEE2...MS004778 (2WD Wagon)
PROBABLE CAUSE
Inadequate grounding of the throttle angle sensor circuit.
CORRECTIVE ACTION
Replace the existing ground wire with the new ground harness listed under PARTS INFORMATION.
1. Disconnect the three-pin connector from the throttle angle sensor.
2. Remove the GRN/WHT wire from the three-pin connector with Pin Tool E, T/N 07JAZ-002050A, from the Terminal Pin Repair Kit (see TOOL INFORMATION).
3. Cut off the GRN/WHT wire as close as possible to the gray tape wrapping the wire harness. Discard the cut off piece.
4. Install the terminal end of the new ground harness into the three-pin connector. Gently pull on the wire to insure the pin is securely locked in the connector.
5. Route the new harness under the existing harness. Hold the harnesses together by wrapping them with 3M 33+ high-temperature electrical tape or equivalent. Wrap the tape as shown, making sure it completely covers the gray tape and any exposed end of the GRN/WHT wire.
6. Remove the bolt holding the harness bracket to the intake manifold. Install the eyelet on the new harness between the bracket and the manifold and reinstall the bolt.
NOTE: The harness eyelet must be installed as explained above. If it is installed between the bolt head and the bracket, the symptoms may not be corrected.
7. Reconnect the three-pin connector to the throttle angle sensor.
8. Test drive the car. Verify that it idles smoothly and at the proper speed.
PARTS INFORMATION
Grounding Harness: P/N 32105-PM5-315
H/C 3976487
TOOL INFORMATION
Terminal Pin Repair Kit: T/N 07JAZ-003000A
H/C 3087707
WARRANTY CLAIM INFORMATION
In warranty: The normal warranty applies.
Out-of-warranty: Any repair performed after warranty expiration may be eligible for goodwill consideration by the District Service Manager. You must request consideration, and get the DSM's decision, before starting work.
Operation number: 121168
Flat rate time: 0.3 hour
Failed part: P/N 32105-PM5-315
H/C 3976487
Defect code: 066
Contention code: C99
Notes
91honda04
Bulletin No.
91-031
Issue Date
NOV. 1, 1991
File Under
ENGINE
Model
'89-91
CIVIC
Applicable To
SEE VEHICLES
AFFECTED
SYMPTOM
VEHICLES AFFECTED
PROBABLE CAUSE
CORRECTIVE ACTION
PARTS INFORMATION
H/C 3976487
TOOL INFORMATION
H/C 3087707
H/C 3976487
Defect code: 066
I performed this TSB on my car and the dealer had to get the part from their national warehouse. It took 2 days. Yes it should still be avalible, my co-worker recently got one for his car. Copy the part number and call them up. You don't need the terminal kit, you can use a straight seal pick to lift up the connector tab inside the connector VERY CAEFULLY. TOO MUCH FORCE AND YOU WILL BREAK IT!! Refer to the TSB for instructions. It should be a Gray wire for the ground. The wire closest to the intake manifold when plugged in. You could also use a wooden tooth pick to ensure you don't break it
kholmes
Oct 12, 2004 06:59 PM
