Exedy Clutch, Fidanza Flywheel, h22, Golden Eagle studs, Edelbrock VictorX, GSR, LSVTEC
Ok here is some stuff i need to sell...
Golden Eagle headstuds, all studs, washers, and nuts...exellent studs, i would take these over ARP's any day. will fit GSR motors and ls/vtec's $80
GSR Edelbrock VictorX manifold...a must have for boosted gsr motors. comes with ALL sensors, plugs, barbed vacumm fittings (IACV, IAT, coolant neck, custom throttle cable bracket for GSR cable and enough barbed fittings to support an entire turbo system) and comes with a hondata thermal gasket...completely plug and play. bolt your fuel injectors and fuel rail on and gain 20-40whp! $300
Next is a Exedy Clutch (pressure plate, and disk) and Fidanza flywheel (11lb i believe) this came off an H22 motor, (probably fits F series motors as well, but im not 100%) clutch and flyweel are in great shape, still tons of life left on the disk, stock like engagement but still holds great power! $185
fast2camciv
Jan 14, 2009 09:44 PM
