Difference of JDM and USDM ITR throttle body
As the title says, if any, what's the difference between the jdm and usdm itr throttle body? Also any difference between the years manufactured? I just bought an ITR gasket and it doesn't fit, it's too small in diameter. I got it from Kragen's so you can't always expect the best part knowledge.
JDM ITR throttle bodies have a port for the EVAP puge. The OBD-2 USDM ITR throttle bodies removed the port.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by autoxthis »</TD></TR><TR><TD CLASS="quote">As the title says, if any, what's the difference between the jdm and usdm itr throttle body? Also any difference between the years manufactured? I just bought an ITR gasket and it doesn't fit, it's too small in diameter. I got it from Kragen's so you can't always expect the best part knowledge.
Are you sure you didnt get a P30? I just got a R TB gasket from acura and used it on my Spoon TB and fitment was fine... just a thought
</TD></TR></TABLE>Are you sure you didnt get a P30? I just got a R TB gasket from acura and used it on my Spoon TB and fitment was fine... just a thought
