help quick!!! what is wrong
Old Jul 25, 2008 | 11:33 AM
elementskaytr16's Avatar
Default help quick!!! what is wrong
ok so there is oil in the radiator does that mean that i have a blown headgasket or what can it mean please help quick so i can figure it out
Old Jul 25, 2008 | 04:41 PM
sprayinBseries's Avatar
Default Re: help quick!!! what is wrong (elementskaytr16)
yeah. usually blown headgasket my friend. fix it before you cause permanent damage. and see what the oil looks like too.
Old Jul 25, 2008 | 04:47 PM
slowcivic2k's Avatar
Are you automatic or manual. If your an auto, I would suspect the cooler leaking into the radiator.
Any coolant in the oil? After the engine stops hot, there is no pressure in the oil orifice, but 13-15psi in the cooling system, that will transfer coolant into the oil.
Are you running a swap/engine with the factory donut oil cooler? (GSR/Type R's have these) Overtightening a filter can crush the separator plates in the cooler, resulting in a oil/coolant mix.
Old Jul 25, 2008 | 04:49 PM
Default Re: help quick!!! what is wrong (slowcivic2k)
yeah that too. just check engine oil. if its a headgasket youll have somewhat milky oil.
Old Jul 25, 2008 | 05:00 PM
Default Re: help quick!!! what is wrong (sprayinBseries)
Dude, did you just read what I posted...... wtf
rcbusiness
Honda Civic (2001 - 2005)
Jul 13, 2017 01:50 PM
Hanmin
11
Apr 25, 2009 09:18 PM
littleblue
Oct 12, 2008 06:16 PM
racingfan
May 2, 2006 11:19 AM
blykins
Jul 25, 2003 09:59 AM
