Lower Octane Gas for 92-93 GSRs?
This may be an odd question.
I'm pretty sure all twin cam vtec hondas require premium fuel due to the higher compression (compared to a B18B or A)
My question, since the B17 is an odd ball...seeing how the compression is in the mid 9's, would you be ablw to get away with middle grade gas? not that I would do it, but just curious if any B17 owners have had any problems using mid grade...knocking, slugginsh starts etc.
Its hard to say because cam timing dictates how much compression the engine actually uses which is the Static vs Dynamic compression ratio. My rule of thumb is anything over 10:1 and I would use 89 or 91 at a minimum. If it under then I would'nt be worried about 87 that much. To be on the safe side though I'd stay within the factory guidelines of the recommended fuel grade if they differ from this.
Modified by DC_Legacy at 1:07 PM 7/25/2008
I've owned my b17 for about fiv years now. I get better gas milage on the BP midgrade than anything else. IT IS IMPORTANT TO BY A QUALITY GAS. Bp is the only thing that I will run if I can help it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jayare05 »</TD></TR><TR><TD CLASS="quote">my buddy put 87 octane in his jdm gsr the other day and it ran like complete crap.. </TD></TR></TABLE>
Ouch....that'll hurt him.
im running midgrade right now on my 92 gsr, it runs fine, but i usually fill up at places like bp, shell, and mobil
then again it is my beater
Eeeek I'd never put 87 in any Honda motor that has a 10 or more compression ratio.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kenni-kins »</TD></TR><TR><TD CLASS="quote">im running midgrade right now on my 92 gsr, it runs fine, but i usually fill up at places like bp, shell, and mobil
then again it is my beater </TD></TR></TABLE>
Yeah, I think it might run OK with midgrade. A 92 GSR beater...brings a tear to my eye
<---apparently a lot of tears!
Cool Cool Island Breezes. BOY-EE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Circusraven »</TD></TR><TR><TD CLASS="quote">
<---apparently a lot of tears!</TD></TR></TABLE>
My 99 GSR knocked on 87 but ran fine on 89. I did it as an experiment...the car was also my beater. You're saving $1-$2 per fill up from downgrading. But the car uses more gas because it has to retard timing....so...you lose $2-$4 there; maybe more.
Why does a 16 year old integra beater bring tears to your eyes? sentimental attatchment? I guess it's kind of a rare car....but...
<---apparently a lot of tears!</TD></TR></TABLE>My 99 GSR knocked on 87 but ran fine on 89. I did it as an experiment...the car was also my beater. You're saving $1-$2 per fill up from downgrading. But the car uses more gas because it has to retard timing....so...you lose $2-$4 there; maybe more.
so did i, man did my friend looked at my stupid. i had an ls n this is my first gsr so i learned already. my car ran like crap while i was racin this gsr hatch.
to me
to me
well the body of my gsr has cancer everywhere, thus the reason why i picked up a DA
<---apparently a lot of tears!</TD></TR></TABLE>well the body of my gsr has cancer everywhere, thus the reason why i picked up a DA
Yeah, being from Chicago, I'm sure you must have plenty of rust. I've always wanted a DA GSR. I'd take it over a DC GSR any day of the week. One of these days
</TD></TR></TABLE>Yeah, being from Chicago, I'm sure you must have plenty of rust. I've always wanted a DA GSR. I'd take it over a DC GSR any day of the week. One of these days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious »</TD></TR><TR><TD CLASS="quote">
I wound,nt have even gambled with it just to see if or how the car would run on 87. It probably retartded its ignition values as much as it could to adapt to the lower octane level, however IMO it probably ran like sh*t because it was pinging.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC_Legacy »</TD></TR><TR><TD CLASS="quote">
I wound,nt have even gambled with it just to see if or how the car would run on 87. It probably retartded its ignition values as much as it could to adapt to the lower octane level, however IMO it probably ran like sh*t because it was pinging. </TD></TR></TABLE>
I drove mostly highway. It ran fine once it wasn't suddenly accelrating. The only reason it knocked is because I'd jump on the gas from 30mph in like 4th or 5th to see if it would knock. Like I said...it was experimental. The manual says you can use 87 in a case wehre 93 isnt available.
The manual says you can use 87 in a case wehre 93 isnt available.</TD></TR></TABLE>
Wow!! Which manual? The OEM/Helms repair manual, or the smaller glove compartment manual/handbook that comes with the car?
I had a JDM b16 OBD0 in my DA and I ran 87 on it for years. Never had an issue and still got good mileage. When i started modding it i switched to 93.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egvtec »</TD></TR><TR><TD CLASS="quote">I read that you can use 87 in the glovebox manual. Im supposing the knock sensor will adjust the timing. probably robs power.</TD></TR></TABLE>
Wow, I did not know that. I guess its good to know incase you endup in BFE and the only fuel grade present is 87 then you can still use it. However IMO the chances of that happening are probably slim to none.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egvtec »</TD></TR><TR><TD CLASS="quote">I ran 87 through my old GSR all the time and it was fine. never even noticed a power loss.</TD></TR></TABLE>
Interesting to know. I would have expected problems with the new generation of GSR motors running 87 more so than the first gen GSR due to the compression differences between the two.
Im thinking the engine just retards the timing to prevent the motor from knocking.
I bet the JDM motors without the knock would ping a bit on 87
JsNA99si
Jun 16, 2004 02:51 PM
