98 Accord Leaking Grease From Under Dashboard???
Old Jul 25, 2008 | 03:38 AM
oldkid6's Avatar
Default 98 Accord Leaking Grease From Under Dashboard???
Has anyone experienced grease leaking from the passenger side underneath the dashboard? I noticed some staining on the carpet next to the center console, then I went to wipe it down to find it was a thick dark orange grease. As I crawled under to take a look, someone had stuffed a bunch of paper towels in there to catch the grease from draining down, but there's so much it still dripped onto the carpet.
I couldn't see exactly where it was coming from. Can someone please tell me where this might be coming from and how to fix it?
Thanks.
Old Jul 25, 2008 | 07:03 AM
Heat's Avatar
Default Re: 98 Accord Leaking Grease From Under Dashboard??? (oldkid6)
Any chance that you could post a picture or two of where you see the towels? You can host a photo at http://imageshack.us/
Old Jul 25, 2008 | 01:24 PM
oldkid6's Avatar
Default Re: 98 Accord Leaking Grease From Under Dashboard??? (Heat)
As you can see, it's weird! I had wiped off an old stain that must have been there for years with carpet cleaner, now I guess the grease just keeps coming back. I inherited this car from a family member and they don't know what it is either. Does anyone know what sits right above that area of the dash that could ooze that type of grease? It's right behind the bottom of the plastic console. Anyone???
Old Jul 25, 2008 | 04:32 PM
Conflicted's Avatar
Have you checked your firewall area? A little further in? It seems as if its being channeled to that area in the car by the curves in the panels.
Old Jul 25, 2008 | 06:05 PM
oldkid6's Avatar
Default Re: (Conflicted)
No I haven't gone back that far. Even if I could back that far to check the firewall, what could it be? What would be in that area would discharge grease?
Bomgart
Jul 13, 2019 08:12 PM
eauto
Jan 12, 2005 07:12 PM
subgeniusdude
Jul 27, 2003 11:14 PM
jeffhdub2(accord)is
May 16, 2003 12:49 PM
90H22
Sep 25, 2002 11:58 AM
