working on harness, i just need some suggestion.
Old Jul 24, 2008 | 11:53 PM
aasaa666's Avatar
Default working on harness, i just need some suggestion.
this is for my 95 Accord EX with H22a1 motor. Im going to fix what the last owner screwed up on -the engine harness. about half a year ago I bought a new a H23 engine harness along with a F22b1 harness. I just need suggestion on how I should mate the 2 to make it work. the F22b1 harness goes from the right side all the way to the left. the H23 harness just goes from the right side and the the left side of the motor and thats it. which portion of which harness do you think i should join. the one part i already know I should use is likely the part of the h23 harness that runs right across the trans for the ect, reverse switch, temp sender, distributor, etc.
Old Jul 25, 2008 | 10:39 PM
aasaa666's Avatar
Default Re: working on harness, i just need some suggestion. (aasaa666)
nevermind I dont need help here. this is easy once i zip tied the f22b1 harness on top of the h23 harness. I wish this tip was online somewhere. Im beginning to see the big picture in a simple form. where the harness branches out its location is almost identical to each other and the drivers side is much longer. now i gotta tranfer the connectors and wiring thats not on the f22a1 harness on to it and relocate some. I can finally make use of the honda de-pinning tool I bought from work.
EJ8CIVIC
Sep 2, 2015 03:59 AM
Tipsy86
Jan 8, 2015 07:22 PM
confusion5
Mar 18, 2004 09:56 PM
