Please Help?
Ok i just bought a 93 accord lx for my daily. The problem is the check engine light comes on at 5 grand and it wont go past 5 grand and then it starts running like **** and smells like its running lean, but then it wont let me go past 3500 rpm once the engine light comes on and then if i turn it off and then it will be real doggy till 4 grand and then its like vtec till 5 but then shuts off again. The motor has been swapped if i did my research correct it should be a f22a7 but it has a f22a4 in if that makes a difference? If anyone can help that would be great!
Thanks alot
Chance
Thanks alot
Chance
Brilliant Idea
What does a Check Engine Light mean?
- there's a problem with the car
Why does it come on?
- so the ECU can tell you the code of the problem
Well why does it do that?
- so you know what the problem is to fix
kenchidi
Transmission & Drivetrain
Dec 22, 2014 02:14 AM
2gen_tegs_rule
Aug 22, 2006 08:12 AM
