New Guy Just Need Some Advice
hey guys I just picked up an 88 CRX DX originally dual point and now has a d16y7 in it with looks to be a botched wiring job car as of now does not run... do you think getting a dual point wiring harness and starting fresh is the way to go and having someone convert it to multi or just buying a multi one and using that will work? Sorry for the nubness wiring is what throws me off
Modified by TweakedTT at 9:08 PM 7/26/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vcrxsir »</TD></TR><TR><TD CLASS="quote">you can not use a mpfi wiring harness in a dx. u have to convert your dpfi harness to mpfi.</TD></TR></TABLE>
yuppers, you are missing hte wires in the strut tower to the ecu.
i use the dx to zc swap from hybrid garage, as a swap atlas.
also, you will need an a6 dizzy unless you converto to obd1. the obd0 cant read the newer dizzy signal.
