Brakes wont build pressure!!
Old Jul 24, 2008 | 06:16 PM
ant$missShift's Avatar
Default Brakes wont build pressure!!
OK. i put DA integra brakes all the around my hatch. new lines / rebuild calipers/ brand new EX 4door 15/16 MC.. i cant get the **** to build pedal pressure. ive bleed and bleed them with nothing. im getting nothing at all on the right side of the car.. just some dribble . and decent pressure on the left side.but still sub par..
ive replace the MC 3 times and bench bleed them all several times..
look all around for leaks.. nothing
changed prop valve.naddas. what could it be?
Old Jul 24, 2008 | 06:22 PM
acmoc's Avatar
Default Re: Brakes wont build pressure!! (ant$missShift)
sounds like the brake booster. Also, you have to bleed the brakes in a certain order I think, different for each car. I went through a whole bottle of brake fluid when I bled mine. So expect that.
Old Jul 29, 2008 | 12:11 PM
Aristotle's Avatar
Usually when brake boosters go bad, they make a hissing sound as if it had a loose vacuum hose, so check vacuum line. You might want to check proportioning valve behind intake manifold on the firewall. And did you pinch the brake lines when you replaced the calipers? Because there might be a small possibility that air reached the brake cylinder, then you would need to to remove the cylinder and bench bleed it.
greenEFhatch
21
Oct 17, 2019 05:00 AM
pineapplemike
Nov 23, 2005 07:25 PM
Integraxnyc
Apr 13, 2004 02:19 PM
GruvyTune
Aug 28, 2001 11:33 AM
