Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
3 times to start new 08 accord v6?
Old Jul 24, 2008 | 03:00 PM
rinwah's Avatar
Default 3 times to start new 08 accord v6?
<1K on the car and it took me 3 times to start it today. Now, (unless it's just me) the idle seems rough. There is a noticeable vibration coming through my feet and my seat. It's not much, but it's there. Of course my option is to take it back to dealer, but with no CELs who knows what they are going to say.
Anyone experience this with new '08?
Old Jul 24, 2008 | 04:36 PM
MSchu's Avatar
My Name is Nobody
Default Re: 3 times to start new 08 accord v6? (rinwah)
No... its not an issue.
at times it takes a crank or two to prime the pump and get the fuel flowing
Modified by MSchu at 6:30 PM 7/24/2008
Old Jul 24, 2008 | 06:16 PM
Ho!cord!V6spd's Avatar
I have had the same problem on my 2005 Coupe.
i recently also had it in the shop to replace the 'bad' throttle body, and it hasn't had the prob since.
Old Jul 25, 2008 | 03:50 AM
MSchu's Avatar
My Name is Nobody
Default Re: (Ho!cord!V6spd)
What portion of the TB was bad? its a mechanical unit, though it is possible that a senor could be bad. the G8 is a throttle by wire unit also, NOT mechanical linkage
Old Jul 25, 2008 | 03:51 AM
rinwah's Avatar
Default Re: 3 times to start new 08 accord v6? (MSchu)
sorry, i accidently deleted your post... but I read it
Modified by MSchu at 5:22 AM 7/25/2008
Old Jul 25, 2008 | 04:23 AM
MSchu's Avatar
My Name is Nobody
I doubt it... hot rodding has little to do with the car running badly. If it was your ecu responding to a tough day, it will return to normal shortly. Could be many things, including the fuel system as I suggested. rough vibrations are directly related to the low idle so they are one in the same. I am sure once the idle raise, it was running fine/smooth again.
Old Jul 25, 2008 | 07:01 AM
rinwah's Avatar
I popped the hood and let it sit for about 3 hours and went back out, drove for about 10 minutes and started it again in my drive way. The idle was back to 700 and no problems. Who knows. The dealer wont find anything anway if there's no CEL. They'll just say they can't duplicate the problem and nothing is wrong. So, I'll be waiting to see if it happens again.
Old Jul 25, 2008 | 07:07 AM
MSchu's Avatar
My Name is Nobody
There ya go... enjoy your ride, the new accord is nice. I love mine
Old Jul 25, 2008 | 03:02 PM
fastaccord213's Avatar
if the problem persists...take it back to the dealer, it should still have warranty right?
http://www.low.com/insurance
Old Jul 26, 2008 | 03:51 PM
spoonfedcrx's Avatar
Default Re: 3 times to start new 08 accord v6? (fastaccord213)
Funny I had an 08 a little while ago that the customer had some "rough running" concerns. During test drive the car seemed to have a miss and when idling it vibrated like a SOB. All of this was intermittent. No CEL. Anyway turns out it had a cracked spark plug. Had under 1000 miles too.
If your car is fine now I wouldn't worry.
Old Jul 26, 2008 | 04:01 PM
MSchu's Avatar
My Name is Nobody
Default Re: 3 times to start new 08 accord v6? (spoonfedcrx)
sure, or even a intermittently firing coil pack could cause a rough idle...
Old Jul 26, 2008 | 08:02 PM
goalscorer's Avatar
Thats weird. Never happened to me.
Old Jul 27, 2008 | 04:29 AM
rinwah's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonfedcrx &raquo;</TD></TR><TR><TD CLASS="quote">Funny I had an 08 a little while ago that the customer had some "rough running" concerns. During test drive the car seemed to have a miss and when idling it vibrated like a SOB. All of this was intermittent. No CEL. Anyway turns out it had a cracked spark plug. Had under 1000 miles too.
If your car is fine now I wouldn't worry.</TD></TR></TABLE>
Thanks spoon! If it happens again, I'll be taking it back.
Old Jul 27, 2008 | 11:49 AM
a sensor in the throttle body was bad, or so I was told. The service guy told me that with a drive by wire system, this kind of problem is A.) harder to diagnose and B.) you can't just replace the sensor
They couldn't replace the sensor by itself, so the whole unit was replaced.
Strange thing is, my TCS light was on when the throttle body went bad.
Old Jul 27, 2008 | 12:01 PM
MSchu's Avatar
My Name is Nobody
I dont believe you can not buy the sensor seperately...
OHhonda99
Sep 30, 2015 11:09 AM
AudioFunk
Aug 20, 2015 02:12 PM
Meyerwi
Dec 24, 2013 06:31 AM
QuickSilverZ
Sep 30, 2012 05:31 PM
jrm86
Dec 20, 2002 11:53 AM
