Difference between 88 Crx HF and 91 Crx Hf motors?
Old Jul 23, 2008 | 03:10 PM
vtecn8ive's Avatar
Default Difference between 88 Crx HF and 91 Crx Hf motors?
I just purchased a spare d15b6 that has lived a little bit of a rough life. Its from a 88 Crx Hf. I was able to purchase the entire swap (motor, tranny, ecu, wiring)
I just cleaned the 88 intake manifold and was planning to install it in my 91 HF but then I got to thinking that maybe there are slight differences I'm not aware of. Everything appears the same.
In the future if/when my motor goes (its a little over 300k, but no smoke and no leaks), i will throw the 88 in until I can fully rebuild. I hope that day does not come any time soon but if there are any parts i should be aware of that are not compatible it would be greatly appreciated.
Things i'm curious about are if the Fuel Injectors the same? compression ratio? intake/exhaust ports same diameter?
thanks again,
Shane
Old Jul 23, 2008 | 07:03 PM
vtecn8ive's Avatar
Default Re: Difference between 88 Crx HF and 91 Crx Hf motors? (vtecn8ive)
bump
Old Jul 23, 2008 | 08:46 PM
mit7059's Avatar
Make sure you use the tranny that came with the 88 engine. The number of splines on the 88 tranny is different than the number on the 89-91s, as a result you can only use 88 engines with 88 trannys and visa versa.
Old Jul 23, 2008 | 08:59 PM
vtecn8ive's Avatar
Default Re: Difference between 88 Crx HF and 91 Crx Hf motors? (mit7059)
sorry should have posted that i'm already aware of the different spline count.
thanks for pointing that out though.
Old Jul 23, 2008 | 11:25 PM
K2e2vin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mit7059 &raquo;</TD></TR><TR><TD CLASS="quote">Make sure you use the tranny that came with the 88 engine. The number of splines on the 88 tranny is different than the number on the 89-91s, as a result you can only use 88 engines with 88 trannys and visa versa.</TD></TR></TABLE>
That is incorrect!
You can use any 88-91 transmission as long as you use a flywheel/clutch that corresponds with the transmission. IE you could bolt up a 91 Si transmission to a 88 HF engine as long as you use a 90-91 clutch/flywheel.
I believe all the HF's are the same; I've never heard anything about them being different(all D15B6).
Old Jul 24, 2008 | 12:17 AM
vtecn8ive's Avatar
Default Re: Difference between 88 Crx HF and 91 Crx Hf motors? (K2e2vin)
Besides the all to familiar different clutch/flywheel/input shaft.
are there any differences anybody would know of?
k20rex
Northwest (Sales)
Jan 8, 2012 08:27 AM
slammedz6ef
Nov 24, 2008 05:23 PM
donaldmejr
Nov 23, 2005 06:55 PM
