b16/b18 parts, ingersoll rand impact, b16 crx mounts,civic hubcaps
allright from the top left corner
b-series header lower pipe only $10 obo
honda lugnuts x15 $5 {or free with steels/hubcaps}
civic hubcaps x4 $20 {lil dirty n scratched}
civic steel wheels x4 $20 local pick up on wheels, 44221, ohio {ones a lil bent, will make deal for $35 on steels/hubcaps/lugnuts}
2nd row
b16a valve cover gasket set $15 {brand new}
b16a timing belt /tensioner $30 {brand new}
b16a intake manifold, obd0 $30 {includes throttle body/injectors/jdm map sensor/tps sensor/fitz valve.. no iac valve}
3rd row
b16a igntion wires,used, work $20
obd0 injector plugs x4 $5
obd0 injector resistor box $10
skunk2 vtec solinoid cover, brand new in box $ 15 {obd0 jdm b16a dohc vtec, may fit others}
88-91 civic/crx b-series engine mounts,new $50
4th row
jdm sir badge, from ebay,new $4
integra leather shift ****, in ok condition $10
95 integra starter,works, 5-spd $35
95 integra alternator,works $30
kms allinminum fit valve block off plate $10 {fast idle thermo valve block off plate}
5th row
hood cable for 88-91 civic/crx w/ handle $20
88-91 civci/crx speedo cable $20
ingersoll rand 1/2 inch drive air impact gun, tnt model, with bootie and fitting, works great $75 FIRM
messsage me with any questions @ goldgreen90ef@yahoo.com , thanks
^^^^^^if u cant find that sensor
ALL THIS PENDING TO SIR ROCKET ON EF-HONDA.COM
all this sold to sir-rocket..
b16a valve cover gasket set $15 {brand new} sold
b16a timing belt /tensioner $30 {brand new} sold
b16a intake manifold, obd0 $30 {includes throttle body/injectors/jdm map sold
sensor/tps sensor/fitz valve.. no iac valve} sold
88-91 civic/crx b-series engine mounts,new $50 sold
95 integra starter,works, 5-spd $35 sold
sold
sold
Various parts FS: CRX OEM Bumpers, B16A head, B16A SiR II cams, PW0/P30 ECU, 3 B-Series Flywheels, a
kur0ryu
Aug 2, 2004 10:01 AM
bigstatik
Jan 16, 2003 05:05 PM
