gap between my siR headlights an corner lights?
One side bolts in but is crooked an the other side wont go in far enough to line the holes up.Both side have a small gap.This is on my siR front end,did I get the wrong corner lights an if so which do I need to remedy this problem.Thanks.
I already tried that but I have an 89 hatch an the stock ones have the 2 screws on the outside where as the jdm ones have the one screw under the hood an 2 slots that it slides into.
Here are some pics of how it should look:
Click to see more:
http://crxfiles.hondapowered.com/march/headlight2.jpg
http://crxfiles.hondapowered.com/march/headlight3.jpg
Click to see more:
Was your car ever hit in the front? Even a small fender bender? If so, then they may not line up correctly. My car was hit in the front by previous owner (93hatch), I'm using SiR headlights, and the driver side would not line up, so I loosened all the bolts, used duct tape to hold the lights together the way they should be, and just started wiggling and pushing the headlight in, until it lined up decent. Mine was also hard because of the A/C lines, and the fact that the SiR headlight is a little deeper. hope it works out for you
Ldo
Jun 5, 2008 03:15 PM
CRXBart
11
Nov 6, 2001 05:02 PM
