Si/Hf ecu pinout different?
Old Jul 23, 2008 | 12:01 AM
ef yu's Avatar
Default Si/Hf ecu pinout different?
reason: have a 90 si motor in my 89 hf.
using hf ecu result: slow and sputters but no check engine for o2 sensor
using Si ecu results: sputters when not warm. warmed up = quick but throws a code for o2sensor.
the question. Is Si and HF ecu pinouts different?
i have bought a brand new O2sensor already.
Old Jul 23, 2008 | 12:37 AM
bobjohnson's Avatar
Default Re: Si/Hf ecu pinout different? (ef yu)
I might be wrong but i think the O2 on the HF is different, so you may need to rewire that.
Old Jul 23, 2008 | 06:07 AM
jlicrx's Avatar
HF and Si ECU pinouts are the same
Old Nov 17, 2010 | 10:13 AM
jdm ef8 89's Avatar
they cant be the exact same because the HF has an EGR valve and the SI has a fast idle control valve. I'm doing the exact same swap and mine runs like shiznit (fast idles not wired throwing codes out the a$$)
Old Nov 17, 2010 | 12:12 PM
jlicrx's Avatar
they are the same:
the HF has yellow wire at ECU pin C8 for EGR - the Si has no wire at C8
the Si has blue wire at ECU pin B2 for FICV - the HF has no wire at B2
FICV missing or not working will not cause a check engine light or codes - neither the 88 Si nor the JDM DOHC ZC have a FICV and either will run just fine using any 88-91 Si PM6 ECU
you probably should look somewhere other than the FICV to cure your codes
Old Nov 17, 2010 | 04:49 PM
1990hondacrx's Avatar
they are exactly the same when i bought my car as a 90 hf first thing i did was pull the hf engine and put a d16z6 with a crx si ecu and it ran fine with no check engine codes for 3 years and chipped the ecu all i did was leave the egr unhooked
CRX MASE
May 19, 2008 03:27 PM
Tyson
Aug 10, 2004 12:50 PM
89POS
Jul 24, 2004 10:29 PM
Broken Gearbox
12
Apr 8, 2004 01:41 PM
allmotorEG-SI
Mar 31, 2002 12:34 PM
