Distributor problem. Electrical spark type noise...
Old Jul 22, 2008 | 11:58 PM
Casey's Avatar
Default Distributor problem. Electrical spark type noise...
I just got my motor back in the car from getting a few things replaced. We wired everything up, vc/thermo and tranny are grounded.
I hooked battery up and cranked the engine over untill the oil light went off. I did not have the ecu plugged in at this time but the dizzy was plugged in(and this may have been my mistake )
once we wired up the plug wires, put the plugs in and plugged the ecu up, the dizzy is making an electrical noise...a constant ticking that can be heard when the key is in the on position, as well as the fuel pump is not priming. idk if they are related but im looking for any help, thanks
Old Jul 23, 2008 | 04:11 AM
walker111's Avatar
Default Re: Distributor problem. Electrical spark type noise... (Casey)
I've never heard the dizzy make any noises when its not in motion. Take it apart and make sure everything is still intact.
Old Jul 23, 2008 | 05:24 AM
Casey's Avatar
Default Re: Distributor problem. Electrical spark type noise... (walker111)
its still in tact for sure. i pulled the cap off to see if there was anything loose. i cant physically see anything wrong, but the noise is arcing coming from somewhere.
Old Jul 23, 2008 | 04:58 PM
97grnrs's Avatar
if its powering its the coil prob .. its live with the key on sometimes. maybe your main relay going bad?
Old Jul 24, 2008 | 03:47 AM
Casey's Avatar
Default Re: Distributor problem. Electrical spark type noise... (97grnrs)
tried new coil and new main relay. spent a total of about 10-12hrs on this and found out my ecu went bad
meanshyguy
Jun 14, 2010 03:45 PM
ghettoSi
Mar 24, 2008 08:14 PM
Haccord21
May 2, 2007 08:35 PM
vbherrera
10
Jan 20, 2007 03:48 AM
JDMhatchback20
Dec 7, 2004 10:27 AM
