90 crx si stock radio
Old Jul 22, 2008 | 10:17 PM
ctang's Avatar
Default 90 crx si stock radio
So i bought a 1990 crx si liek amonth ago and first thing i wanted inside was the headunit. As i was going to hook it up i noticed the stock radio wire harness was cliped off and a pioneer was replaced with it
So i replaced it wtih a DC2 stock radio wire harness and i ran into another problem. From the car stock wires i missing a green/white wire and from the DC2 wire harness theres red/yellow and green/yellow missing. I just wanted to make sure if these were wires that i didnt have to hook up ? when i did wire it up it ended up like this
Old Jul 23, 2008 | 04:04 AM
Red_ED8's Avatar
Default Re: 90 crx si stock radio (ctang)
This is a link to a honda radio wiring chart (found in the FAQ's):
http://www.installdr.com/Harnesses/HA-Wiring.pdf
The Yellow wire wire red strip should be the 12 volt power but I don't see a yellow wire with green strip? maybe the color on my screen is messed up so correct me if I'm just not seeing the colors right.
Old Jul 23, 2008 | 04:14 AM
JustAnotherRex's Avatar
Check out the radio wiring chart above and double check all of your wires.
A DC might well have had a couple of things a CRX wouldn't have - our cars were a bit more spartan than Integras.
Old Jul 23, 2008 | 02:08 PM
ctang's Avatar
Default Re: (JustAnotherRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red_ED8 &raquo;</TD></TR><TR><TD CLASS="quote">This is a link to a honda radio wiring chart (found in the FAQ's):
The Yellow wire wire red strip should be the 12 volt power but I don't see a yellow wire with green strip? maybe the color on my screen is messed up so correct me if I'm just not seeing the colors right.</TD></TR></TABLE>
Thanks alot that helped me !
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JustAnotherRex &raquo;</TD></TR><TR><TD CLASS="quote">Check out the radio wiring chart above and double check all of your wires.
A DC might well have had a couple of things a CRX wouldn't have - our cars were a bit more spartan than Integras. </TD></TR></TABLE>
Hahah yeh i figured that out when i was trying to wire the dc wire. damn previous owner was an idiot
1990AccordEX
Audio / Security / Video
Dec 13, 2006 08:30 AM
roterx7
Mar 8, 2006 03:15 PM
mirakulist
Feb 28, 2005 12:16 PM
Full Race A6
Jun 12, 2004 05:04 AM
