Smoke at Start Up?
Old Jul 22, 2008 | 08:30 PM
HondaS2000's Avatar
Default Smoke at Start Up?
I got a jdm b16a, and what i start it up, usually when its cold it smokes a lil but then it stops. any ideas what that means?
Old Jul 22, 2008 | 08:36 PM
BlueIntegraBoy's Avatar
Default Re: Smoke at Start Up? (HondaS2000)
Color of smoke? Probably just condensation.
Old Jul 22, 2008 | 08:49 PM
HondaS2000's Avatar
white
Old Jul 22, 2008 | 08:52 PM
Default Re: (HondaS2000)
Smell like oil or just exhaust fumes?
Old Jul 22, 2008 | 08:56 PM
HondaS2000's Avatar
actually im sorry the smoke is blue, not white, smells like oil
Old Jul 22, 2008 | 09:05 PM
Mr. Giggles's Avatar
-Get a compression test/leakdown done..
-Blue smoke is usually an indication of burning oil from what i understand whether it is under acceleration or startup...(Def on acceleration...)
Under acceleration if you see blue smoke it is most likely pistons rings, but if you just start up it is probably your valves..
Edit, just found this link by searching:
https://honda-tech.com/zerothread?id=2259298
Schister gives very good advice..
Old Jul 22, 2008 | 09:07 PM
Valve stem seals are bad as a possibility if only at startup.
Old Jul 22, 2008 | 09:09 PM
HondaS2000's Avatar
how hard are the valve stem seals to change? And yes it is only at start up, goes away when start driving.
Modified by HondaS2000 at 10:16 PM 7/22/2008
Old Jul 22, 2008 | 09:13 PM
EkFG's Avatar
your lucky its just valve stem seals, replacing them with the head off is pretty easy but with the head on the motor it takes some skill's.
Old Jul 22, 2008 | 09:17 PM
HondaS2000's Avatar
ok so yall dont think its piston rings??
batallic
Oct 4, 2011 12:36 PM
jaredvabeach
Aug 13, 2008 01:21 PM
jit01
19
Nov 13, 2007 09:01 AM
steveo135
Nov 5, 2007 11:41 AM
