lack of power 1.6
Old Jul 22, 2008 | 04:10 PM
mattscivic1's Avatar
Default lack of power 1.6
i have a 97 civic ex with a 1.6 non vtec. wen i hit the gas is has no power at all. i have check the fuel presure,spark,wires,cap and rotor all is great. when i hit the gas and spay carb cleaner in the throtlle body it runs great.
maybe map sensor?
any help would be great!
Old Jul 22, 2008 | 04:14 PM
94EG8's Avatar
Seagull Management
Default Re: lack of power 1.6 (mattscivic1)
if its an EX it should be Vtec, did it just start doing this? is it showing an CELs? and if you spray carb cleaner in anything it'll run great, its very combustible stuff.
Old Jul 22, 2008 | 04:18 PM
Default Re: lack of power 1.6 (94EG8)
well the engine came out of an 00 lx that is non vtec.....
the old engine was a vetc
Old Jul 22, 2008 | 04:19 PM
94EG8's Avatar
Seagull Management
when you swapped the engine did you swap the ecu as well?
Old Jul 22, 2008 | 04:20 PM
nope do you think i need to?
wow i fell dumb
Old Jul 22, 2008 | 04:25 PM
94EG8's Avatar
Seagull Management
You should swap it out for a P2E, its the correct ecu for the engine. Asking questions isn't dumb, not asking questions and guessing when someone could give you an answer is dumb in my opinion, trial and error and figuring things out on your own are good too
Old Jul 22, 2008 | 04:30 PM
spotscivic's Avatar
turbo it.lol
Old Jul 22, 2008 | 06:09 PM
Convert's Avatar
Default Re: lack of power 1.6 (spotscivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spotscivic &raquo;</TD></TR><TR><TD CLASS="quote">turbo it.lol</TD></TR></TABLE>
i lol'd. This reminds me of the VW forums, except with them, it was always "slam it."
Too bad VWs are so unreliable. I miss that underpowere pos sometimes......
Old Jul 23, 2008 | 11:48 AM
Default Re: lack of power 1.6 (Convert)
where whould i get one and how much do you think it would cost.
Old Jul 23, 2008 | 12:37 PM
blk92_d16's Avatar
Look at the F/S section on here if you can, or if you're a member of other Honda forums. Or ebay of course...
Old Jul 23, 2008 | 01:05 PM
HoNda PriNcess's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattscivic1 &raquo;</TD></TR><TR><TD CLASS="quote">i have a 97 civic ex with a 1.6 non vtec. wen i hit the gas is has no power at all. i have check the fuel presure,spark,wires,cap and rotor all is great. when i hit the gas and spay carb cleaner in the throtlle body it runs great.
maybe map sensor?
any help would be great!</TD></TR></TABLE>
Haha, I just had to make a comment about the carborator cleaner. Its like, guys seem to believe if they have simple green, brake cleaner or carb cleaner with a couple of zip ties anything is fixable I sat outside for four hours last summer and scrubbed all the **** off of a valve cover in simple green. I won't got near that crap again!
Walker Hall
Honda Civic (2001 - 2005)
Dec 1, 2016 01:44 PM
Goran
15
Nov 14, 2016 09:49 PM
rsxs77
10
Feb 1, 2014 04:19 PM
mattscivic1
Oct 26, 2008 04:21 PM
