HELP!!!! Hood Latch / Cable Problem
Old Jul 22, 2008 | 03:38 PM
boostedhks's Avatar
Default HELP!!!! Hood Latch / Cable Problem
i have a problem, i replaced my hood latch and cable for my 95 honda civic dx 2dr. However, the cable seems to be working fine (the old one didn't seemed to grab good) but the hood latch doesn't want to close the hood, like it doesn't lock it as it should to be released by the hood cable. Is there anything that i should of done to the hood latch or cable when installing them ? why could this be happening ?
Note: The hood closes to a point that you could open it with the switch that you have to pull up under the hood but it doesn't completely closes as it should.
Old Jul 22, 2008 | 05:06 PM
vtecb18c's Avatar
Default Re: HELP!!!! Hood Latch / Cable Problem (boostedhks)
spray wd40 on the latch thats welded to the car..sometimes it gets stuck open and wont allow the hood to latch
Old Jul 23, 2008 | 06:54 PM
boostedhks's Avatar
i will try that, however the latch is not welded onto the car... i got the hood latch from a junk yard.
Old Jul 24, 2008 | 01:04 PM
blk92_d16's Avatar
i had to replace a latch too, and mine "new" still doesn't work at 100% Before closing the hood I have to manually pull a metal piece over in order for the 2-stage locking piece work right. Spray it all down good, examine how the thing actually operates, and then see which piece isn't moving or broken.
GL!
Old Jul 24, 2008 | 07:43 PM
boostedhks's Avatar
wait, what piece is that, could u give me some detailed explanation so i could try to figure this out cuz today i was looking at it and it looks like it is supposed to close where it is but it looks like the headlights is stopping it to go farther down but that's right where it lines up so it shouldnt go down any more.... :X could u give me some details please ?? thanks in advance
Old Jul 24, 2008 | 07:45 PM
OMGWTFBBQ!'s Avatar
Have you tried sitting on your hood to close it?
That solved my hood being more open than it should be problem.
90si-rex
11
Dec 4, 2008 07:05 PM
fongyz22
Honda Civic (2001 - 2005)
Sep 28, 2007 08:25 AM
blueaccord94
Mar 26, 2005 07:53 PM
scrolanky
Jan 21, 2004 05:21 PM
