will brakes off an 88 teg work?
Old Jul 22, 2008 | 03:21 PM
turboblack2door's Avatar
Default will brakes off an 88 teg work?
could i do the disk brake conversion with the trailing arms and everything with the 88 teg. Also are the brakes the same size and everything?
Old Jul 22, 2008 | 03:27 PM
EL Vap133's Avatar
Default Re: will brakes off an 88 teg work? (turboblack2door)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboblack2door &raquo;</TD></TR><TR><TD CLASS="quote">could i do the disk brake conversion with the trailing arms and everything with the 88 teg. Also are the brakes the same size and everything?</TD></TR></TABLE>
No they will not fit, that platform Integra was different.
Old Jul 22, 2008 | 03:31 PM
Default Re: will brakes off an 88 teg work? (EL Vap133)
are the gsr and the ls brakes any diff size between the years of 94-2000
Old Jul 22, 2008 | 03:41 PM
_Keith_'s Avatar
just get some da alls you need is the rear hub that bolts to the trailing arm... dont need the whole arm.
Old Jul 22, 2008 | 04:51 PM
supersteven's Avatar
No. GSR and LS are the same.
Old Jul 23, 2008 | 05:30 AM
Default Re: will brakes off an 88 teg work? (supersteven)
thanks for the info
B-serious
Jul 15, 2008 08:13 AM
Bob_Digi
Aug 22, 2003 08:03 AM
99civic_exSB
Jun 2, 2003 11:52 AM
lsvtecrx
22
Nov 8, 2002 02:02 AM
