02 RSX-S Exhaust Leak Question
Old Jul 22, 2008 | 03:00 PM
sloweh3's Avatar
Default 02 RSX-S Exhaust Leak Question
I've got an 02 RSX-S. I've got a slight exhaust leak, but cannot tell where it is coming from. If you put a rag over the muffler, you cant hear a leak at all. But when you are driving, it sounds like a leak around the exhaust manifold. I was wondering if anyone else has had this problem.
I've checked out the spring bolts, and they are tight, so is every other bolt on the exhaust. I've also had it on a lift and put it in first and went from first to second and to third, but cant hear anything if it is in the air. But when it is on the ground and you are driving it, you can definitely hear an exhaust leak. I've had a few mechanics take a look at it and they're stumped as well. Thanks.
Old Jul 22, 2008 | 04:34 PM
rip_dc5's Avatar
Default Re: 02 RSX-S Exhaust Leak Question (sloweh3)
have u checked your donut gasket from the header to were it meets the piping cause i had the same problem i replaced it problem solved
Old Jul 22, 2008 | 09:02 PM
sloweh3's Avatar
Default Re: 02 RSX-S Exhaust Leak Question (rip_dc5)
no, i haven't checked it. what size is the gasket on the type-s exhaust manifold?
Old Jul 23, 2008 | 09:51 AM
rip_dc5's Avatar
dont really know the size i just went to the dealer and ordered it it was like 20 bux
Old Jul 23, 2008 | 10:29 AM
pcorad's Avatar
I had the same problem. Under acceleration, the springs allowed a gap where the donut should be sealing. I think we replaced the springs in addition to the donut.
Old Jul 23, 2008 | 01:33 PM
sloweh3's Avatar
Default Re: 02 RSX-S Exhaust Leak Question (pcorad)
ok, i got on acuraautomotiveparts.org to order the parts. i'm gonna order the spring bolts and the doughnut gasket. it looks like 17 is the doughnut gasket, but i'm not 100% sure
the link to the site is:
http://www.acuraautomotivepart...ormal
Old Jul 23, 2008 | 02:57 PM
dx_rex's Avatar
i thought my two peice was leaking from that same spring bolt area so i bought a one peice and ended up with the same leaking sound eventually..? i found that where my header bolts up to the head, that gasket was going bad now im in the process of finding a decent aftermarket gasket for that ish!and this time ill use a tourqe wrench to put that effer on..!
Old Jul 23, 2008 | 02:58 PM
rip_dc5's Avatar
yeah its 17 just make sure to be careful with the o2 sensor connections cause when i was puttin mine on i pulled the 4 wires on it
Old Jul 26, 2008 | 10:39 AM
thetunersource's Avatar
i hate exhaust leaks, causes such a headache
Old Jul 26, 2008 | 03:54 PM
sloweh3's Avatar
Default Re: 02 RSX-S Exhaust Leak Question (thetunersource)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thetunersource &raquo;</TD></TR><TR><TD CLASS="quote">i hate exhaust leaks, causes such a headache</TD></TR></TABLE>
lol, yea they do. it's been doing it since i bought the car, and i've been trying to figure out where it was coming from so i wouldn't waste my money on parts that wouldn't fix it
Old Jul 28, 2008 | 09:48 AM
stokelessdc5's Avatar
I don't remember seeing adonut gasket when I installed mt rch? I think mine is leaking from the gasket too. That or where the headers connect to the exhaust sys.
PowerLeg
Jan 2, 2009 11:39 PM
allricedout
Mar 14, 2007 06:33 PM
acidburn2k2
Jan 7, 2006 01:03 PM
CO Wagofan
11
Sep 17, 2004 09:51 AM
