What is this part called?
I believe its called the knee bolster. If call a junkyard and it explain it to them they'll probably understand what your talking about.
Um...
Actually that's called a 'cover assembly' not a 'knee bolster'.
Any time you see 'bolster' it refers to a metal piece (behind the plastic cover assembly, in this case) that bolsters its strength!
Do you mean #17 in the pic?
77301-S04-G00ZB COVER, INSTRUMENT DRIVER (LOWER) $25.00
----------------------(CLASSY GRAY) (TypeK (dark)interior)
'96-'00 6th gen all the same part# unless different color (TypeF or TypeP interior)
Modified by TheJGB3 at 12:44 AM 7/23/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecb18c »</TD></TR><TR><TD CLASS="quote">they didnt steal the car for that, they needed that to get to the ignition
The ignition is under the steering column cover. That's what they broke in mine to get to the ignition so they could break that too.
</TD></TR></TABLE>The ignition is under the steering column cover. That's what they broke in mine to get to the ignition so they could break that too.
erikiksaz1
19
Jul 23, 2004 01:54 AM
