Motor in a 98 civic EX
Old Jul 22, 2008 | 11:45 AM
DOUBLExDEUCEx22's Avatar
Default Motor in a 98 civic EX
Ive got a 98 civic EX 2dr coupe. this might be a stupid question but what motor do i have?.. im pretty sure all EX have Vtec but i wanted to make sure.. i know its a 1.6L but not much else. also whats a good price for some new spark plug wires.. mine are stock and i should probably get some new ones.
Thanks,
Nick
Old Jul 22, 2008 | 11:58 AM
mofo951's Avatar
I believe they have a D16Y8. Correct me if i'm wrong.
Old Jul 22, 2008 | 12:07 PM
blk92_d16's Avatar
Correct, D16Y8...the most notorious series for spun bearings. Instead for new wires (unless you have issues with the OEM ones) might I recommend an oil pressure gauge or shimming the pump for more psi.
NGK wires should run you about $50-60.
Old Jul 22, 2008 | 12:08 PM
The Collin's Avatar
x3 on D16y8.
x2 on NGK's.
Old Jul 22, 2008 | 12:12 PM
Default Re: (99_hb_on_air)
ok thanks.. but i still would like to know if it has a V-tec... like i said im pretty sure it does. and dont give me that well cant you read stuff because not all v-tecs say v-tec on them
Old Jul 22, 2008 | 12:20 PM
halocore's Avatar
Default Re: (DOUBLExDEUCEx22)
It has vtec, when i first got mine i wasn't sure either only because I've seen so many older model ex that says Vtec on the valve cover.
Old Jul 22, 2008 | 12:27 PM
The Collin's Avatar
If it's the original motor, then yes it's a d16y8 w/VTEC. I have a spare VTEC valve cover if you'd like for me to ship it to you.
Old Jul 22, 2008 | 12:50 PM
that would be sweet... what color is it? how much would it be to ship do you know?
Old Jul 22, 2008 | 02:52 PM
im in 53188 waukesha WI, i think you would need that to know how much it will be. ill give you my entire adress once we figure out shipping stuff
sicivicsniper
15
Apr 14, 2005 05:11 PM
usdm97DC4
Apr 5, 2005 06:20 AM
WHiTETYPEs
Jan 10, 2005 07:37 PM
OldSkoolCiv
Nov 4, 2004 09:36 PM
twotone
16
Oct 4, 2002 08:43 AM
