What kind of cyc. compression result are people getting with 84mm 9:1
Old Jul 22, 2008 | 11:39 AM
eg:R's Avatar
Default What kind of cyc. compression result are people getting with 84mm 9:1
did a compression test and number seem to be low . range around 155psi on all 4 cyc.
Old Jul 22, 2008 | 11:42 AM
tony413's Avatar
I have that type of compression on a 8.4:1cr motor.
i would say you probably should be around 180psi go do a leakdown test and see what condition the motors in
Old Jul 22, 2008 | 11:53 AM
.CUBISH.'s Avatar
Default Re: (tony413)
mine is at 185 across..
84.5mm cp 9 to 1's
89mm crank
gsr head
.040 head gasket
Old Jul 22, 2008 | 12:05 PM
sewell94's Avatar
depends on alot of factors which include, what head, what gasket, how much material has been machined off, and what cams you have. etc etc
I'd do a leakdown if your worried.
Modified by sewell94 at 1:14 PM 7/22/2008
Old Jul 22, 2008 | 12:46 PM
morgan@synapse motorsport's Avatar
Default Re: (sewell94)
i saw 195-200 across the board on my 84mm 9:1. this is with reshaped chambers which reduce compression a little bit. 155 does seem a bit low.
Old Jul 22, 2008 | 01:14 PM
hotrod99's Avatar
Default Re: (mike@synapse motorsport)
I got 180 across with 84mm 9 to 1 pistons and .056 headgasket which calculated to 8 to 1 compression
Old Jul 22, 2008 | 04:25 PM
tony413's Avatar
Default Re: (hotrod99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotrod99 &raquo;</TD></TR><TR><TD CLASS="quote">I got 180 across with 84mm 9 to 1 pistons and .056 headgasket which calculated to 8 to 1 compression</TD></TR></TABLE>
your a tad bit high for a 8:1 compression motor.
Old Jul 22, 2008 | 06:27 PM
hbyrd8701's Avatar
Default Re: What kind of cyc. compression result are people getting with 84mm 9:1 (eg:R)
sorry to thread jack, I have 81.5 9 to 1 and my compression is about 220 across
Old Jul 22, 2008 | 06:38 PM
eg:R's Avatar
motor is a gsr bore 84mm w/ itr cams. motor has about 1,000 miles on it. stock factory head gasket w/ no head shave.
Old Jul 22, 2008 | 06:47 PM
DaveF's Avatar
Default Re: What kind of cyc. compression result are people getting with 84mm 9:1 (hbyrd8701)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hbyrd8701 &raquo;</TD></TR><TR><TD CLASS="quote">sorry to thread jack, I have 81.5 9 to 1 and my compression is about 220 across</TD></TR></TABLE>
i have the same thing only pumping 155 !
maybe your guage is off (to the OP)
have you tried a differant tester ?
Old Jul 22, 2008 | 06:54 PM
eg:R's Avatar
Default Re: What kind of cyc. compression result are people getting with 84mm 9:1 (DaveF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaveF &raquo;</TD></TR><TR><TD CLASS="quote">
have you tried a differant tester ?</TD></TR></TABLE>
im not sure if the guage is off but i will try another one and see. maybe do a leakdown test while im at it.
Old Jul 22, 2008 | 08:15 PM
locash's Avatar
Honestly, if all cylinders are equal, and leakdown is minimal, you're probably just fine.
Old Jul 23, 2008 | 03:41 AM
non-VTEC's Avatar
180-190 with the throttle open.
Old Jul 23, 2008 | 05:34 AM
2redstars's Avatar
did you shut the fuel off when you did it?
Old Jul 23, 2008 | 06:06 AM
blackeg's Avatar
Default Re: (2redstars)
also do you have it wide open when cranking?
i run 9:1. b16 head itr cams, gsr block 84mm with ls crank. i see between 190 and 195 compression, 6 cranks hot motor when its wide open
Old Jul 23, 2008 | 02:21 PM
Kevin's Avatar
Default Re: (blackeg)
84mm, 9:1 cp, 89mm crank, milled b16 head, oem hg - 183-185 across.
Old Jul 23, 2008 | 03:46 PM
eg:R's Avatar
Default Re: (Kevin)
ok i did another compression check and leak down on my motor. 7 cranks with fuel shut off and wide open throttle for compression check. NO oil was added to cyl. TDC for every cyl. test on leak down. motor was warm up before all testing.
compression test cyl. / leak down
#4- 157psi leak down- 50%
#3- 145psi leak down- 65%
#2- 160psi leak down- 40%
#1- 157pis leak down- 40%
Old Jul 23, 2008 | 07:13 PM
vesperfx's Avatar
83mm cp 9.1, oem headgasket i got 200 even across.
Old Jul 24, 2008 | 05:45 AM
blackeg's Avatar
Default Re: (vesperfx)
where was the air leaking down from? was it coming through the valves or the crank breathers? if it was the valves...are you dead sure your timing is on?
Old Jul 24, 2008 | 10:40 AM
Boosted_B_Series's Avatar
81mm 9:1 gsr oem hg 180psi across the board here
Old Jul 24, 2008 | 12:50 PM
eg:R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">where was the air leaking down from? was it coming through the valves or the crank breathers? if it was the valves...are you dead sure your timing is on?</TD></TR></TABLE>
i didnt check where the air was leaking from. the timing was on tdc on every cyl. before leakdown. are the leak down test results normal? when the engine is on idle i can see some white smoke coming out from crank breather of valve cover.
Old Jul 26, 2008 | 09:58 PM
blinx9900's Avatar
150 across with my 8.3:1 motor! your a bit low... but if its consistant i would not really worry...
Old Jul 26, 2008 | 10:05 PM
Muckman's Avatar
Moderator in Chief
Im 84mm at 9:1 and I have 195+ psi on a COLD motor across all cylinders. Im very happy with the ring gaps I did on this motor. I was 180+psi on the last build, same bore and CR.
Old Jul 27, 2008 | 10:22 AM
A.E Motoring's Avatar
Default Re: What kind of cyc. compression result are people getting with 84mm 9:1 (Muckman)
u do it when the motor was warm?
Old Jul 27, 2008 | 11:17 AM
eg:R's Avatar
Default Re: What kind of cyc. compression result are people getting with 84mm 9:1 (A.E Motoring)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by A.E Motoring &raquo;</TD></TR><TR><TD CLASS="quote">u do it when the motor was warm?</TD></TR></TABLE>
yes the engine was warm and ring gaps were gap to spec from the box.
