Which A/C Bracket for EF?
I have a 1990 Si with a B16A, SiR engine swap and I would like to have the A/C working. I have ALL of the A/C stuff including the D-Series compressor that came with the original Si engine. Is the Hasport A/C bracket the only item I need for a direct fit? Can I use the original Si Idler pulley?
I think HAsport is the only way to go. Another company may have made one but I havent kept up.
http://www.hasport.com/tech/installs/EFAC.pdf
That link should tell you what all you need to run the HASport one.
