Help with front wheel bearings ASAP!!
Old Jul 22, 2008 | 11:26 AM
Jizzo's Avatar
Default Help with front wheel bearings ASAP!!
I was inspecting the brakes on my nieces 90 Accord and found out that the rotors were worn out so i decided to replace the rotors too. When I took out the four 12 point bolts in the back the the hub didn't come off so i took a slide hammer and hit off. When it came off part of the bearing came off with the hub too but luckily I got that off with some help. So now I have decided to replace the bearings too but the wheel bearings wont come off. Shouldn't it have come off when I took the 12 point bolts out? I tried taking off the guard but I think the screws are rusted on there. I was thinking about torching it but was afraid I might mess up the lower ball joint because there was a screw thats near the ball joint. I need to fix this by Thursday so any help would be appreciated!
Old Jul 23, 2008 | 12:15 PM
shutgun21's Avatar
Default Re: Help with front wheel bearings ASAP!! (Jizzo)
the wheel bearing must be pressed out. remove the whole knuckle and put it in a press. itll be fine.
Old Jul 27, 2008 | 06:52 PM
Jizzo's Avatar
Default Re: Help with front wheel bearings ASAP!! (shutgun21)
Thanks! It was a !@#$%, but I got it done!
mwr1964
Aug 23, 2010 06:02 AM
rcgrillo
Sep 8, 2008 04:38 PM
bigislandc2
May 20, 2007 09:45 AM
Shay91Racer
Apr 25, 2007 07:29 PM
low430
Aug 29, 2005 08:32 AM
