Saggy Door???
Old Jul 22, 2008 | 10:41 AM
Si-Samuri's Avatar
Default Saggy Door???
The driver side door on my 1991 CRX Si seems to be sagging a little bit, meaning it gets caught when i close it. If i lift the door slightly it closes smooth. Has any one had this problem and how have they gone about fixing it. I am assuming I need to replace the hinges. If there is a write-up on it someone please forward me the link. Any help is appreciated.
Old Jul 22, 2008 | 12:22 PM
Creator's Avatar
Default Re: Saggy Door??? (Si-Samuri)
You should take a good look at what your dealing with first. It could be that the metal on the door has cracked or fatigued in which case you may need a whole door. I've seen people try to get crafty and weld a plate in to repair such a problem, but it always returns.
good luck
Old Jul 22, 2008 | 01:02 PM
Red_ED8's Avatar
Default Re: Saggy Door??? (Creator)
It's the door hinges, 90% of old cars I've seen with this problem had worn out hinges (not just honda's).
Old Jul 23, 2008 | 09:30 AM
Si-Samuri's Avatar
Yea im thinking its the hinges the door shows no signs of cracking or anything.
Old Jul 23, 2008 | 09:52 AM
jdm206's Avatar
Default Re: (Si-Samuri)
its your door hinge, because i had the same problem on my 91 hatch. all i did was change both hinges and the door closed perfect now.
Old Jul 23, 2008 | 11:33 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: (jdm206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm206 &raquo;</TD></TR><TR><TD CLASS="quote">its your door hinge, because i had the same problem on my 91 hatch. all i did was change both hinges and the door closed perfect now. </TD></TR></TABLE>
fergs96integra
Feb 7, 2024 06:11 AM
efiftythree
Jun 6, 2020 01:14 PM
hondaon18's
Jan 2, 2013 07:02 PM
tegpilot007
Oct 25, 2005 05:16 PM
PatrickGSR94
Feb 10, 2004 03:38 AM
