What am i doing wrong? Zc distributor help
Old Jul 22, 2008 | 09:20 AM
91civicZcSw4p's Avatar
Default What am i doing wrong? Zc distributor help
so i have a 1991 civic Dx with a Dohc Zc motor swap, i think iether the coil or the ignighter went out on it so i replaced them both and got a new cap and rotor for the distributor, i went to wire it back up and now i have no spark! im sure i wired everything up correctly, but it just wont start, before i took the thing apart it worked, but it would bog alot going uphill and when in a lower rpm in a higher gear. what can i be doing wrong? is there a ground somewhere i dont see? or a relay? if anyone has an answer for me that would be great! cuz i need to get to work!
Old Jul 22, 2008 | 01:21 PM
black0hatch's Avatar
Default Re: What am i doing wrong? Zc distributor help (91civicZcSw4p)
are you getting power to the coil?
Old Jul 22, 2008 | 01:44 PM
jlicrx's Avatar
do you have the spark plu wires in the correct location on the distributor?
JT2MA71
Apr 5, 2007 10:50 PM
scratchline20
May 9, 2003 08:05 AM
TRE_
Mar 30, 2003 08:29 PM
Stebo77
Dec 16, 2002 01:10 PM
