Progress Auto 88-91 Civic/CRX 24mm Rear Sway Bar
Old Jul 22, 2008 | 09:18 AM
2.0L EK's Avatar
Default Progress Auto 88-91 Civic/CRX 24mm Rear Sway Bar
http://www.progressauto.com/
Part Number 62.1001
Brand New In Box
$220 + Shipping
Item descriptions
Part Number: 62.1001
Adjustment Range: Sliding range
End-links Included: Yes
Rear anti-roll bar
Progress Suspension anti-roll bars dramatically improve handling. How? They minimize the traction-robbing body “lean” that rolls part of the outside tires off the pavement. Our Sport-tuned Anti-roll bars replace skinny OEM bars and rubber bushings with larger diameter (stiffer) alloy steel bars and polyurethane bushings. More roll stiffness means less body “lean”, and the tires stay flatter on the pavement (larger contact patches). The result is more grip and added driver control!
* Less body roll means more traction, faster cornering speeds, and increased driver confidence.
* Polyurethane bushings produce crisp response on turn-in.
Progress Anti-roll bars are cold-formed in-house using our custom-built precision bending equipment. Both laser-cut and CNC bar ends are MIG welded in place using a precise fixture for an exact fit.
Thanks
Alex
crispikreme@yahoo.com
Old Jul 23, 2008 | 08:45 AM
2.0L EK's Avatar
Default Re: Progress Auto 88-91 Civic/CRX 24mm Rear Sway Bar (2.0L EK)
Ldo
Apr 12, 2009 10:38 PM
CRX_Honda
27
Feb 26, 2009 11:35 AM
lsteg07
Feb 10, 2005 09:47 PM
bluef
Oct 24, 2002 08:05 AM
