buring oil
Old Jul 22, 2008 | 08:44 AM
boarding2008's Avatar
Default buring oil
I have a 92 Accord automatic and If i let my car sit for a day or two and then start it, a lot of gray/blue smoke comes from the exhaust . i put a bootle of lucas engine oil to stop that but it hasnt. any ideas on how to fix. Thanks in advance
Old Jul 22, 2008 | 09:30 AM
GhostAccord's Avatar
Default Re: buring oil (boarding2008)
Replace the valve seals.
Old Jul 22, 2008 | 11:02 AM
FunnyVictor86's Avatar
if that doesnt work ... which it should ... try heavier weight oil ... im sure the car has high milage
Old Jul 22, 2008 | 11:27 AM
Yeah it has 170K or so on it. I switched to a heavier wieghted oil and it still smokes just not as bad. Ill prob replace the vavle seals.
Thanks again
Old Jul 23, 2008 | 12:12 PM
shutgun21's Avatar
yes the valve seals should do it. can be done with out removing ur head...
Old Jul 23, 2008 | 03:36 PM
mavvrik's Avatar
Word cotton.
New valve seals and you'll be set! Just watch that blue smoke. Make sure you manage that motor. By manage I mean put heavier oil in (10W-30 maybe?) and make sure you do it regulerly.
Old Jul 23, 2008 | 05:19 PM
yeah thats what im using now, 10w-30. i check my oil often cuz i know it was burning it, just did know exactly wut would basically be a for sure fix. I'm gonna fix the seal this weekend most likely. il let ya know how it goes lol.
Modified by boarding2008 at 10:49 PM 7/23/2008
Old Jul 23, 2008 | 05:35 PM
sun_zinc's Avatar
Default Re: (boarding2008)
only for couple seconds or continuous
Old Jul 23, 2008 | 06:52 PM
Default Re: (sun_zinc)
i would say it does that untill it gets warmed up or for a few mins. if it a cold morning it looks like a smoke screen lol.
Old Jul 24, 2008 | 05:56 AM
mavvrik's Avatar
Haha. Yeah bro, because of the age on that motor you'll need to start putting granny fluids in it hahaha jk
Im just messing around with you. Honestly, like I said before, just watch the color of that smoke. It's probably going to smoke a little white because of how old it is. What i'm getting at is the compression probably isn't what it use to be...hense the white smoke.
Old Jul 24, 2008 | 02:46 PM
sun_zinc's Avatar
if only beginning, more likely from valve. if continuously, could be piston rings and oils bypassing.
Old Jul 24, 2008 | 05:16 PM
yeah it is only for a few mins, it stops once the car is warmed up or just as the needle rises. btw thanks for all of the input, its cool how many people help after one answer is given lol
Lawbags
Oct 9, 2017 03:37 PM
mr_munro
29
Oct 27, 2010 10:20 AM
Jax4gencivic
May 4, 2006 07:59 AM
SpeedMachine
Apr 29, 2005 12:27 AM
