need to lube my power windows
Old Jul 21, 2008 | 10:35 PM
361 accord's Avatar
Default need to lube my power windows
what do yall use, quick!
yes i know this is the wrong section, i heart accord forum, buut they are all old and go to bed early
in particular the windo regulator i think its gettin kind stiff towards the top
Old Jul 21, 2008 | 10:39 PM
YeuEmMaiMai's Avatar
Default Re: need to lube my power windows (361 accord)
if it's the rails use use lithium if it is the guides use silicone.
Old Jul 21, 2008 | 10:44 PM
The Phil's Avatar
You don't.
Old Jul 21, 2008 | 11:08 PM
361 accord's Avatar
Default Re: need to lube my power windows (The Phil)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Phil &raquo;</TD></TR><TR><TD CLASS="quote">You don't.</TD></TR></TABLE> i know you shoulda have to, but the car was parked in the garage for like a year
the motors are new though
Old Jul 21, 2008 | 11:09 PM
361 accord's Avatar
Default Re: need to lube my power windows (YeuEmMaiMai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">if it's the rails use use lithium if it is the guides use silicone.</TD></TR></TABLE>yar i have neither, idk which one it is, it just kinda wants to get stuck towards the top
Old Jul 21, 2008 | 11:44 PM
lube the window track (ie the area the window slides into)
Old Jul 22, 2008 | 12:00 AM
Solless's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">lube the window track (ie the area the window slides into)</TD></TR></TABLE>
Shin-Etsu Grease
Old Jul 22, 2008 | 12:13 AM
Tornadom's Avatar
I use white lithium grease on my truck.
Old Jul 22, 2008 | 06:04 AM
B16SolMan's Avatar
New User
White lith sucks, just use some regular grease, people overuse white lith and end up using it on a lot of things that it isn't gonna do any good for.
Old Jul 22, 2008 | 06:13 AM
DRAMA's Avatar
axle grease
Old Jul 22, 2008 | 06:24 AM
BauleyCivic's Avatar
Risky Business
Default Re: (DRAMA)
Anti seize lubricant is the best **** ever, too bad it is silver and is messy.
Old Jul 22, 2008 | 06:27 AM
someone else's Avatar
It Wasn't Me!
Default Re: (BauleyCivic)
White lithium for the regulator, lightly applied silicone paste for the run channels. Do not use WD40, especially on the run channels.
EDIT: Clean the run channels before lubing them.
Old Jul 22, 2008 | 06:30 AM
Stockton's Avatar
Replace the regulators they're just going to fail.
Old Jul 22, 2008 | 06:55 AM
361 accord's Avatar
Default Re: need to lube my power windows (Stockton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stockton &raquo;</TD></TR><TR><TD CLASS="quote">Replace the regulators they're just going to fail.</TD></TR></TABLE>naa i replaced both front motors and regulators about the same time 4-6 months ago (not including 2 semesters hardparking)
ive still got 3 other windows, A/C and a sunroof so its not that bad, just need to get silicone and white lithium, sux
so, should these be spray, or liquidey paste, or straght up thick *** grease? how to apply?
i know i am gonna have to take off the door pane already
Old Jul 22, 2008 | 06:57 PM
It Wasn't Me!
The silicone paste we use for run channels at work is called Shin-Etsu.
Clean the run channel with soap and water and let it dry. Apply the lube and let it sit for a couple minutes. Then wipe off the residual. The seals should feel kind of oily but not have any excess because it just attracts dust.
If you are going to have the door panels off do the same with the lower run channel while the window is up.
The #1 cause of regulator failure on Hondas is the run channels getting sticky and straining the regulator. Especially on pre 2001 Civic coupes and hatches. Keep them clean and lubed and you won't have problems. I do mine every 3 months.
Old Jul 22, 2008 | 08:36 PM
361 accord's Avatar
Default Re: need to lube my power windows (someone else)
soooo lower the window and clean the felt stuff? and lube the felt stuff
im lazy and dont really want to take of the door panel cuz i havwe power everything available and im lazy to undo ann the clips
AND peel back the damn plastic sheet too
Old Jul 22, 2008 | 10:11 PM
The Phil's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 361 accord &raquo;</TD></TR><TR><TD CLASS="quote">soooo lower the window and clean the felt stuff? and lube the felt stuff
AND peel back the damn plastic sheet too </TD></TR></TABLE>
Then DON'T LUBE THE DAMNED WINDOWS!
Either do it right, or don't do it at all. This half assed **** is how problems happen.
Old Jul 22, 2008 | 10:47 PM
361 accord's Avatar
Either do it right, or don't do it at all. This half assed **** is how problems happen.</TD></TR></TABLE> makes sense, im just feeling lazy right now
pics of that to lube up that doesnt ibvolve taking **** apart, i know where to lube inside
just the idea of putting any kind of grease on felt seems rediculous, though maybe i could clean them?
Old Jul 23, 2008 | 07:57 AM
It Wasn't Me!
Not the felts the run channel, the rubber track the window slides up and down in. If you don't know what I mean I'll try to post a picture when I get home tonight.
Clean and lube the run channels with the window down. Then if you are going to have the door panels off clean the lower portion that is in the door.
Don't put anything on the felts. LOL. That would just make a mess.
Old Jul 23, 2008 | 09:54 PM
361 accord's backup acct.'s Avatar
* B A N N E D *
From: original join date 1/3/07, add 2884 posts, jdm yo
i can has pics?
Old Jul 23, 2008 | 11:07 PM
onepoint6i's Avatar
Default Re: need to lube my power windows (361 accord's backup acct.)
honda silicon spray...the best
Old Jul 24, 2008 | 12:57 PM
It Wasn't Me!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 361 accord’s backup acct. &raquo;</TD></TR><TR><TD CLASS="quote">i can has pics?</TD></TR></TABLE>
Sorry, had some girl problems last night. Will try to remember tonight.
Old Jul 24, 2008 | 01:39 PM
* B A N N E D *
Default Re: need to lube my power windows (onepoint6i)
ya but where the hell do it put it!!!!, oh well, its raining probably so that will either solve the problem, or, i wont need them
BJA86
Audio / Security / Video
23
Nov 11, 2007 04:01 PM
viciousef9
Oct 7, 2007 01:04 AM
viciousef9
Oct 6, 2007 10:14 PM
85
Honda Motorcycles
Sep 16, 2004 04:19 PM
GreenBean
Apr 13, 2003 01:43 PM
