ex tran on lx?
Old Jul 21, 2008 | 08:25 PM
freakasis's Avatar
Default ex tran on lx?
i got a 93 civic lx automatic and need a trans...a buddy of mine has a 93 civic ex automatic trans that he doesnt need....i know it will bolt up but will the shift points be all screwed up? will i even notice? will it be better?
Old Jul 21, 2008 | 08:29 PM
97Ej6mike's Avatar
all 1992-2000 5speed trannys are one and the same as far as size goes, and will bolt up without a problem. The EX tranny is shorter than the LX is, and you will notice a satisfying difference in gearing ratios between shifts.
Old Jul 21, 2008 | 10:27 PM
Historyg's Avatar
mike the op is talking about auto tranny's not manual, you must have been tried. The auto tranny i believe will bolt in, but you might need a ex ecu for the gearing to be the same, I hope someone with auto exp can help you.
Old Jul 22, 2008 | 05:20 AM
freakasis's Avatar
bump...whats it gonna be like if i use the stock lx ecu?
Old Jul 22, 2008 | 05:34 AM
94EG8's Avatar
Seagull Management
Default Re: (freakasis)
So far as i know there is no difference between the automatic EG D-series trannys. Manuals yes there is in terms of gear ratios, but i believe the automatics are the same across the board.
Old Jul 22, 2008 | 06:05 AM
freakasis's Avatar
they have differant part numbers and show differant in every exchange computer iv seen...so i know there is a differance...im pretty sure the vtec auto trannies would have a differant final drive or at least differant gearing.
Old Jul 22, 2008 | 06:10 AM
94EG8's Avatar
Seagull Management
I'm not gonna say your wrong, but i think they're the same, they definately have the same final drive, 4.33 across the board, thats straight out of the '94 civic sedan brochure. they might have differnt gearing, but where the final drive is the same i doubt it.
Old Jul 22, 2008 | 01:04 PM
blk92_d16's Avatar
If you have access to a Helms manual, peer into the first 30 pages and I'll give you the ratios for the different transmissions. I can only guess you'll probably need an EX auto ecu...but that's not for sure.
GL!
Old Jul 22, 2008 | 01:34 PM
94EG8's Avatar
Seagull Management
Ok, i finally did a little digging around, checked mitchell, both trannys are stamped M24A actually all EG automatic trannys are M24A, so as far as i can tell there is no difference, as i said earlier the final drive is very definately 4.33 across the board.
Old Jul 23, 2008 | 05:31 PM
freakasis's Avatar
sweet...thax man, i dont have the helms manual for it or i wouldda done it. i wouldda thought that honda wouldda dont some modification the the vtec trans since its gotta rev out further, but i guess not.
The_Head
Dec 17, 2011 11:11 AM
FIVESTARR*EM2
Honda Civic (2001 - 2005)
10
Oct 15, 2007 07:19 PM
jdeemseerx
Feb 28, 2007 09:35 AM
crxnonvtec
Dec 22, 2005 10:44 AM
fireant
Aug 24, 2002 06:34 PM
