anyone ever use a sce copper head gasket?
Old Jul 21, 2008 | 08:00 PM
ITR.#1446's Avatar
Default anyone ever use a sce copper head gasket?
With my turbo i bought i received a .080 thick copper head gasket. I have never really seen one before and i was wondering if it is a good product to use or not? It says i need to take out the middle layer on the head gasket and spray the copper head gasket with copper spray place the stock outers on it and i guess torque it to factory specs but i am unsure what the torque specs are. Jw if this is something i should try out or not let me know what you think thanks guys.
Old Jul 21, 2008 | 10:51 PM
hotrod99's Avatar
Default Re: anyone ever use a sce copper head gasket? (ITR.#1446)
I wouldnt trust anything other than OEM or GE and you said it was .80 that is really thick
Old Jul 21, 2008 | 10:54 PM
ITR.#1446's Avatar
Default Re: anyone ever use a sce copper head gasket? (hotrod99)
yeah i did alot of research on here and found 99% of the threads people said no
Old Jul 22, 2008 | 01:16 AM
The sweed's Avatar
Copper head gaskets are usualy used with steel o-rings in the deck or in the head. I think that is an old school way of fixing bad designed oem gaskets on older tuned cars.. A multi layer steel gasket is as good as i gets.. If you want that seal stronger a I would use copper o-rings in the deck surfice. If you brakes oem multilayer gaskets I would guess that you ether have a bad tune or that your sealing surfice is bad or your head studs are bad.
Old Jul 22, 2008 | 01:45 AM
rebo0t's Avatar
you would need to run o-ring.
new_climber
Honda Civic (2001 - 2005)
Aug 28, 2023 12:11 PM
night
40
Jul 8, 2011 02:09 PM
Joeski99Si
Apr 23, 2009 05:24 AM
Joeski99Si
Apr 22, 2009 09:57 PM
rice4life
24
Mar 12, 2005 12:39 PM
