225's on a 15inch oem rim, what tire pressue??
Old Jul 21, 2008 | 06:20 PM
blackeg's Avatar
Default 225's on a 15inch oem rim, what tire pressue??
making my first trip to the track this week with some new bfg 225s on some gsr hammers. how low on the tire pressure can i go? i used to run my 205s at 10 psi but is that too low considering how much bigger the tire is than the rim?
Old Jul 21, 2008 | 07:52 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: 225's on a 15inch oem rim, what tire pressue?? (blackeg)
driving style and track prep will very, start at 18-20 and work your way down. i personally ran at 9-12 depending on the track and i cut 1.8-1.9'a all day
Old Jul 21, 2008 | 09:01 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: 225's on a 15inch oem rim, what tire pressue?? (S@nt0s)
start dropping pressure until your trap speed does the same
Old Jul 22, 2008 | 07:57 AM
blackeg's Avatar
Default Re: 225's on a 15inch oem rim, what tire pressue?? (Evs-One)
ok cool. i just wasnt sure if i had to keep a decent amount of air in it because its on a thin rim. ill probably start around 12 and see how that goes. i know they usually go up a few psi after the burnout and run anyhow
Old Jul 22, 2008 | 01:48 PM
nonvtecallmotor's Avatar
I raced them as low as 6psi. I've been as fast as 11.1 and 141mph
Old Jul 22, 2008 | 04:26 PM
lude98SH's Avatar
Default Re: 225's on a 15inch oem rim, what tire pressue?? (nonvtecallmotor)
are these radial tires ?
Old Jul 22, 2008 | 05:45 PM
96 GSR-T's Avatar
wow 6psi holy hell, I will be running tomorrow on 225 BFG's, never would of imagined going that low with them. Guess ill start at 14 and go from there.....
Old Jul 27, 2008 | 10:08 AM
Default Re: 225's on a 15inch oem rim, what tire pressue?? (lude98SH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude98SH &raquo;</TD></TR><TR><TD CLASS="quote">are these radial tires ? </TD></TR></TABLE>Yes
beeyond built
May 14, 2009 10:32 PM
EJtypeR
Mar 22, 2005 10:49 AM
udm_motorsport
Mar 22, 2004 02:53 PM
chrisb
27
Aug 14, 2002 06:26 AM
jonnybravo
Jun 11, 2002 01:18 PM
