FS: Sony 40" Bravia XBR-Series LCD HDTV
Old Jul 21, 2008 | 05:14 PM
asianeric's Avatar
Default FS: Sony 40" Bravia XBR-Series LCD HDTV
comes with 5 year warranty, originally purchased from fry's electronics in april, need the cash, so i have to let it go....
$1900obo (payed about 2200 with warranty)
The XBR line of Full HD 1080p televisions incorporate all of Sony's latest technologies. Motionflow™ 120Hz enables smoother motion when viewing movies or fast-action sports. Bravia Engine PRO with Digital Reality Creation upconverts all interlaced and progressive video signals including HD signals directly to 1080p for amazing detail and sharpness. Now your LCD TV can be as distinctive as your own personal style.
The Basics
Display type: Flat-panel LCD
Screen resolution: 1080p (1920 x 1080)
Aspect ratio: 16:9
Contrast ratio: 18,000:1 dynamic contrast ratio
Tuner type: NTSC, ATSC, QAM
Connection options
HDMI inputs: 3, Supports 480i/480p/720p/1080i/1080p.
Component inputs: 2, Supports 480i/480p/720p/1080i.
PC inputs: 1
See specifications table for more feature and connection options
Dimensions
Height: 25.9" (28.2" on optional base)
Width: 43.7"
Depth: 4.8" (12.7" on optional base)
Weight: 58 lbs. (69 lbs. on optional base)
Features
Full HD 1080: There are a lot of ways to define high-definition, but Bravia Full HD means you’re getting the best resolution that high-definition has to offer. With Sony Bravia XBR HDTVs, Full HD 1080 means 1920 x 1080 pixels and 1080p video inputs.
1920 x 1080 panel resolution: Full HD 1920 x 1080 panel resolution with over 2 million pixels (more than twice that of 720p HDTV) is exactly what you need to reproduce the 1080p content that can be delivered by the cutting edge 1080p Blu-ray disc player. When working with Bravia Engine PRO, everything from standard definition to high definition is upconverted to 1080p for a picture so real it’s like you’re actually there.
Motionflow 120 Hz frame rate: Achieving smoother, natural motion reproduction starts with the right performance characteristics such as the ultra-fast panel response times Bravia HD LCD TVs have. Sony's Motionflow High Frame Rate technology doubles the amount of frames from 60fps to 120fps, and does it the right way by using real-time calculation of every single frame of video to create entire new frames of information.
10-bit processing and display: Sony follows 10-bit processing with a 10-bit panel that, compared to an 8-bit panel, supports 64 times the levels of color expression. The bottom line: smoother transitions from color to color and subtle, faithfully-reproduced color changes.
Bravia Engine PRO: Sony improved on the great benefits of the Bravia Engine in the XBR4 by adding a picture quality enhancement circuit called Digital Reality Creation Multi-function v2.5. It now has the added ability to process interlaced and progressive video signals and because it has twice the processing power of previous DRC-MF circuits, it can do its processing and output them to 1080p. Add to this the crisp details, outstanding contrast, eye popping colors, and dramatically reduced digital artifacts that DRC-MF circuitry is known for. And the best part of all is that DRC-MF v.2.5 is user-adjustable according to the video source.
Live Color Creation™: Live Color Creation starts with the Bravia Engine PRO video processing system, which enhances primary colors and corrects half-tone colors for natural overall color. Next, a WCG-CCFL backlight using Sony’s phosphor formula delivers a specific spectrum of light designed to work with our specially formulated color filters. The combination of these three components creates deep blues and natural greens for overall colors that draw you right into the picture.
x.v.Color technology: 1.8 times as many natural colors as existing HDTV signals will now be faithfully reproduced. x.v.Color is the name Sony has chosen to promote video products that include xvYCC capability. x.v.Color enabled products can now offer more accurate color reproduction and natural colors.
Old Jul 21, 2008 | 07:18 PM
asianeric's Avatar
bumpppp
da9nguyen87
Nov 30, 2008 07:55 AM
.Thomas
Feb 1, 2007 01:48 PM
Type X
Aug 4, 2004 03:16 PM
